Bad Times at the El Royale - Fails to decrypt
stuckinkodiagain
Post by stuckinkodiagain » Tue Jan 01, 2019 4:49 am
The "Bad Times at the El Royale" (2018) UHD blu-ray fails to decrypt in the latest version of MakeMKV (1.14.2). The dump file has been submitted to svq@makemkv.com.
Thanks, and Happy New Year, everyone!
saf001
Re: Bad Times at the El Royale - Fails to decrypt
Post by saf001 » Thu Jan 03, 2019 12:17 am
I'm having a similar issue with mine. Should I also submit one or is one enough?
Same issue with Night School - both 4k discs. Figured maybe it is still a bit early for the information to make it since I only received my copies today.
stuckinkodiagain
Post by stuckinkodiagain » Thu Jan 03, 2019 3:30 am
No harm in submitting another dump, if you’d like.
And yeah, I find that new releases have trouble with MakeMKV until the decryption comes through. Turnaround is usually within the first 3-4 days before you can decrypt it, but obviously that varies based on the schedules of the developers. (Damn them for having lives of their own, y’know?)
saf001
Post by saf001 » Thu Jan 03, 2019 10:50 pm
Hi stuckinkodiagain - did you try El Royale again? I just tried and it appears to be working ok. I also submitted my dump yesterday.
stuckinkodiagain
Post by stuckinkodiagain » Fri Jan 04, 2019 3:11 am
Works just fine now! Thanks to the devs!
Post by SamuriHL » Fri Jan 04, 2019 10:41 pm
Just bought this disc myself. This could be a fun one to play with since it's the first Fox title (that I'm aware of) that has HDR10+. Let the games begin! :D
FatMike
Post by FatMike » Thu Jan 24, 2019 6:57 am
Just finished, worked fine for me as well. Thanks all!
