Network file creation issue (Bug)
marklw
Post by marklw » Fri Apr 24, 2009 2:23 am
I'm running 1.4.1, I can read files from a network just fine, but no matter what I try I can't send output to a network share. (Apologies if this is already noted).
Re: Network file creation issue (Bug)
Post by mike admin » Fri Apr 24, 2009 11:57 am
very strage, it should just work. Can you please enable "log debug messages" in preferences, restart MakeMKV, try to create a file on network and post the log here?
marklw
Post by marklw » Mon Apr 27, 2009 9:27 pm
I did as you asked. But it does not seem to be creating a log file any place that I can find. I checked the default 'c:\Program Files\MakeMKV' area and 'C:\'... so if you have the file placed in another location please direct me and I will grab it.
Errors I get on the screen:
1. Dirctory //<path>/Temp/disk1 does not exist. Do you want to create it? (answer yes even though I created the dir manually)
2.Dirctory //<path>/Temp/disk1 is invalid (press Ok)
No other details.
Post by mike admin » Fri May 01, 2009 6:19 pm
This is good enough, thank you.
