makemkv not showing tracks that
nicolai
#1 Post by nicolai » Mon Jan 21, 2019 8:57 pm
I use makemkv 1.14.2 on Linux.
I have here the scandinavian DVD issue of Asterix The Mansions of the Gods. It has a trick title inventory but vlc shows that I want title 56. VLC and lsdvd and makemkv shows the same number of tracks/titles
This is in the log of makemkv:
Cells 8-8 were removed from title end
Title #56 was added (6 cell(s), 1:21:56)
Title #58 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The playback length agrees with VLC.
lsdvd shows:
Title: 55, Length: 00:00:10.400 Chapters: 02, Cells: 02, Audio streams: 05, Subpictures: 00
Title: 56, Length: 01:22:00.040 Chapters: 07, Cells: 08, Audio streams: 05, Subpictures: 00
Title: 57, Length: 00:00:00.400 Chapters: 01, Cells: 01, Audio streams: 05, Subpictures: 00
Makemkv shows "title_t04" with source title ID 49 and then "title_t05" with source title ID 91.
Why does makemkv seem to add title 56 to the title list and then not show it in the gui to select?
There seems to be one or two older posts with a similar theme, but no resolution.
Thanks for any help.
usydj33jjks
Re: makemkv not showing tracks that
#2 Post by usydj33jjks » Mon Jan 28, 2019 8:12 pm
Have you tried "Open DVD manually"? https://www.makemkv.com/manualdvd/
Best regards,
Z
