DVD of 'The Devils' won't rip
ek1949
#1 Post by ek1949 » Wed Jan 16, 2019 6:46 pm
I'm new to the forum so I don't know very much about ripping except that I've used MakeMKV for many years without ever having a problem. Now I have a DVD of the film 'The Devils' and it has me stumped. I've run it twice and it stalls out, first before it shows the title, and then when it finally gets to the titles it won't rip what's chosen.
This is what I got on the last run:
MakeMKV v1.14.1 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Owner/MakeMKV_log.txt
The new version 1.14.2 is available for download at http://www.makemkv.com/download/
Cells 14-15 were skipped due to cell commands (structure protection?)
Cells 18-end were skipped due to cell commands (structure protection?)
Title #1 was added (12 cell(s), 1:46:36)
Title #2 was added (1 cell(s), 0:02:04)
Title #3 was added (1 cell(s), 0:03:48)
Title #4 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 was added (5 cell(s), 0:25:43)
Title #7 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
DEBUG: Code 10551311 at =so$Z|i}"9H2)y>n:213142496
DEBUG: Code 0 at =so$Z|i}"9H2)y>n:121274998
DEBUG: Code 0 at Y.aF2=qB"!l"+[S_ x:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-2 were removed from title start
DEBUG: Code 69496 at bXZ/tMv<]ykA@D:213133158
DEBUG: Code 69497 at bXZ/tMv<]ykA@D:121264993
DEBUG: Code 69497 at Y.aF2=qB"!l"+[S_ x:29400991
DEBUG: Code 1 at Y.aF2=qB"!l"+[S_ x:29379394
Title #13 was added (24 cell(s), 1:49:01)
Cells 2-end were skipped due to cell commands (structure protection?)
Title #14/0/1 was added (16 cell(s), 1:47:39)
Title #15/0/1 was added (18 cell(s), 1:48:11)
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '3047424'
DEBUG: Code 101000192 at eJ[G2qt+,=.<H`5ee>:29395080
DEBUG: Code 0 at `[r5Fs9aFRAS=X49:213130743
DEBUG: Code 0 at TjbMdp36,cm3Gi-:29401635
DEBUG: Code 0 at zJl[8<g?!2\+9a:213134883
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '0'
DEBUG: Code 0 at zJl[8<g?!2\+9a:121266603
Encountered 3 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
Re: DVD of 'The Devils' won't rip
#2 Post by Woodstock » Wed Jan 16, 2019 7:26 pm
Two things to try. Download the newest version (you're one behind), and clean the disk.
The read errors you're getting are often from the disk simply being "dirty". This topic in the Blu-ray forum explains a lot about this, as well as the link in your log, http://www.makemkv.com/errors/dvdread/
