UHD Bluray taking forever to copy, is this normal?
Morganator
Post by Morganator » Tue Jan 15, 2019 8:10 pm
Hi, im in the process of copying Everest 4k bluray. Its in the supported hashed keys. However its taking forever to do. So far its been running for nearly 12 hours and the remaining time in increasing rather than decreasing. All other disks only take about 2 hours to complete. Its a high spec system its running on too. What could it be taking so long? Here is a log of the operation:
MakeMKV v1.14.2 win(x64-release) started
Evaluation period not started, shareware functionality unavailable.
Downloading latest SDF to C:\Users\mini_/.MakeMKV ...
This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details.
File 00016.mpls was added as title #0
Title #00029.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.mpls was added as title #1
Title #00027.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.mpls was added as title #2
Title #00005.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00094.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00091.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 3 titles into directory F:/4K films from disc using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:aac-st.mmcp.xml'
Failed to save title 0 to file F:/4K films from disc/Everest_t00.mkv
0 titles saved, 3 failed
Saving 3 titles into directory C:/Users/mini_/Desktop/4k films from disc using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:aac-st.mmcp.xml'
AV sync issue in stream 0 at 0:52:14.568 : video frame timecode differs by -20.859ms
AV sync issue in stream 0 at 0:52:14.610 : video frame timecode differs by -20.856ms
AV sync issue in stream 0 at 0:52:14.652 : video frame timecode differs by -20.854ms
AV sync issue in stream 0 at 0:52:14.694 : video frame timecode differs by -20.862ms
AV sync issue in stream 0 at 0:52:14.777 : video frame timecode differs by -20.856ms
AV sync issue in stream 0 at 0:52:14.819 : video frame timecode differs by -20.854ms
AV sync issue in stream 0 at 0:52:14.860 : video frame timecode differs by -20.862ms
Forced subtitles track #11 turned out to be empty and was removed from output file
Forced subtitles track #13 turned out to be empty and was removed from output file
Forced subtitles track #15 turned out to be empty and was removed from output file
Forced subtitles track #17 turned out to be empty and was removed from output file
Forced subtitles track #19 turned out to be empty and was removed from output file
Forced subtitles track #21 turned out to be empty and was removed from output file
Forced subtitles track #23 turned out to be empty and was removed from output file
Forced subtitles track #25 turned out to be empty and was removed from output file
Forced subtitles track #27 turned out to be empty and was removed from output file
Forced subtitles track #29 turned out to be empty and was removed from output file
Forced subtitles track #31 turned out to be empty and was removed from output file
Forced subtitles track #33 turned out to be empty and was removed from output file
Forced subtitles track #35 turned out to be empty and was removed from output file
Forced subtitles track #37 turned out to be empty and was removed from output file
Forced subtitles track #39 turned out to be empty and was removed from output file
Forced subtitles track #41 turned out to be empty and was removed from output file
Forced subtitles track #43 turned out to be empty and was removed from output file
Forced subtitles track #45 turned out to be empty and was removed from output file
AV sync issue in stream 0 at 2:01:11.180 : video stream has 8 frames with invalid timecodes
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00017.m2ts' at offset '0'
Failed to save title 1 to file C:/Users/mini_/Desktop/4k films from disc/Everest_t01.mkv (I aborted the process at this stage)
Re: UHD Bluray taking forever to copy, is this normal?
Post by Woodstock » Tue Jan 15, 2019 11:30 pm
What happens if you install Java, as recommended, to mitigate the Java-based encryption?
handcraftedbits
Post by handcraftedbits » Wed Jan 16, 2019 3:24 am
I would think the read errors are the more pressing issue. Clean it thoroughly, then clean it again. UHDs are really picky.
Morganator
Post by Morganator » Wed Jan 16, 2019 1:43 pm
Woodstock wrote: Tue Jan 15, 2019 11:30 pm What happens if you install Java, as recommended, to mitigate the Java-based encryption?
Haha I noticed this in the log after writing the initial post. I've now installed java and going to try again soon. Thanks
handcraftedbits wrote: Wed Jan 16, 2019 3:24 am I would think the read errors are the more pressing issue. Clean it thoroughly, then clean it again. UHDs are really picky.
Thanks for your response. Sorry could you clarify what you mean by clean and clean again. Thanks
Post by Woodstock » Wed Jan 16, 2019 1:46 pm
Start here: viewtopic.php?f=8&t=15055
I had missed the hardware errors listed in your log.
handcraftedbits
Post by handcraftedbits » Wed Jan 16, 2019 6:10 pm
Morganator wrote: Wed Jan 16, 2019 1:43 pm Thanks for your response. Sorry could you clarify what you mean by clean and clean again. Thanks
Just a bit of exaggeration. What I mean is clean the disc thoroughly, and even if it looks perfect it may still have issues. You may have to clean it multiple times before you can get a clean rip.
