Dolby Atmos
kkahn
Dolby Atmos
Post by kkahn »
I have ripped Deadpool, the Fith Element, Baker runner 2049, Bladerunenr; however, I do not see an Atmos track (all of these movies should have Atmos). The highest rated track is Dolby TruHD 7.1. Is there any fix?
aerandir92
Re: Dolby Atmos
Post by aerandir92 »
That is the Atmos track. Atmos is sort of baked into the Dolby TrueHD track. If you play it on a supported player you will see that it plays Atmos
While Dolby Atmos and Dolby TrueHD are two separate soundtrack formats, Atmos data on Ultra HD Blu-ray is actually an extension to TrueHD that is folded into the bitstream to maintain backwards compatibility. Here’s how that works: If you play a disc with an Atmos soundtrack, the Atmos extension data is decoded by an Atmos-compatible receiver. If your receiver isn’t Atmos compatible, the extension data is ignored and the soundtrack is decoded as regular Dolby TrueHD.
Read more at https://www.soundandvision.com/content/ ... cmeP732.99
TheShoe
Re: Dolby Atmos
Post by TheShoe »
it is like the DTS Core track where DTS-MA sits on top of it. gives you that BC capability when needed
