[Feature Request] Conversation Profil Audio->AC3 5.1
Dazkine
Post by Dazkine » Sun Jan 13, 2019 11:53 pm
Hello
A lot of Smart TV manufacturers have no DTS support in their devices because of license payments they want to avoid. Even manufactures like Panasonic or Samsung with DTS support in the past drop DTS in their newer TVs since 2016/2017.
Flac 5.1 und AAC5.1 are kind of an exot when it comes to multi channel audio so im wondering if there is a way to add a conversation profil into the software that converts DTS(HD) into AC3 or perhaps even E-AC5.1 ?
AC3 (Dolby Digital) is a simple basic multi channel audio format that nearly every SmartTV device is able to deal with in these days. For DTS thats not the case.
Re: [Feature Request] Conversation Profil Audio->AC3 5.1
Post by Woodstock » Mon Jan 14, 2019 6:11 am
If you're looking for something more immediate, handbrake can do such conversions while it's also shrinking the video. And you can use the ffmpeg command line to convert JUST the audio, if you are a stickler for "exact video quality".
goonielife
Post by goonielife » Fri Feb 01, 2019 4:48 pm
Something like AVIdemux can convert the audio while leaving the video intact.
Gogitow
Post by Gogitow » Mon Feb 18, 2019 5:41 pm
I think the post you are looking for is:
viewtopic.php?t=7293
If you dive into this topic it will basically help you create an AC3 profile for Makemkv that will convert pretty much any format to AC3 while ripping discs.
viewtopic.php?t=8547
may also be helpful.
I have a Plex server which I use with the Plex app on my Tivo Bolt. The Tivo Bolt only like H264 video with either AAC or AC3 audio. About half of my Blu Rays which I ripped with Makemkv are already in H264 video but only have DTS tracks on them. If you create file mentioned in the above forum posts you will be able to convert the audio while leaving the video alone which saves a bunch of time. Hope this was helpful.
