Please help! Starts converting and then stops and says a fatal error has occured and the program will now exit.
Mac OS 10.6.4 build10F569
2.93 GHz Intel Core 2 4 gb 1067 DDR3 ram
MKV 10.5.8 darwin x86 release
Manufacturer: PIONEER
Product: BD-ROM BDC-202
Revision: 1.01
Serial number: GEDL000457WL
Disc Information
Data capacity: 37.41 Gb
Disc type: HD DVD-ROM
Number of layers: 1 (PTP)
Disc type: BD-ROM
Number of layers: 2
Error log is as follows:
Debug log started at Tue Aug 3 16:41:10 2010 , written by MakeMKV v1.5.8 darwin(x86-release)
001005:0000 MakeMKV v1.5.8 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/jclay/MakeMKV_log.txt
005074:0000 Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
002010:0000 Optical drive "DVD+R-DL PIONEER DVD-RW DVRTS08 Q81D" opened in OS access mode.
002010:0000 Optical drive "BD-RE PIONEER BD-ROM BDC-202 1.01" opened in OS access mode.
001003:0020 DEBUG: Code 1073741829 at f'/en*`b3u>-149*tp:121263636
001003:0020 DEBUG: Code 1073741829 at f'/en*`b3u>-149*tp:213130007
002003:0000 Error 'Posix error - Input/output error' occured while reading 'DVD+R-DL PIONEER DVD-RW DVRTS08 Q81D' at offset '524288'
002003:0000 Error 'Posix error - Input/output error' occured while reading 'DVD+R-DL PIONEER DVD-RW DVRTS08 Q81D' at offset '1048576'
001003:0020 DEBUG: Code 1073741829 at f'/en*`b3u>-149*tp:213132376
002003:0000 Error 'Posix error - Input/output error' occured while reading 'DVD+R-DL PIONEER DVD-RW DVRTS08 Q81D' at offset '32768'
001003:0020 DEBUG: Code 0 at M;Jxmda%Ro>*T_N`"tv:29393447
DISCID=A51E306D60F7A07C60F102BE78FB8FA51E594877
003307:0000 File 00000.mpls was added as title #0
003307:0000 File 00019.mpls was added as title #1
003025:0000 Title #00011.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00017.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.m2ts has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00019.m2ts was added as title #2
003025:0000 Title #00022.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00031.m2ts was added as title #3
003307:0000 File 00032.m2ts was added as title #4
003307:0000 File 00033.m2ts was added as title #5
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory /Users/desktop
002003:0000 Error 'Posix error - Input/output error' occured while reading '/BDMV/STREAM/00028.m2ts' at offset '1209987072'
001003:0020 DEBUG: Code 0 at sfv%EBueDm$.k:[.:213136769
001003:0020 DEBUG: Code 0 at UKb-R!zFS.iX#kwq&S$x:213130628
001003:0020 DEBUG: Code 0 at e1%ukWK;dJG*]Y(z}xsB:213129823
001003:0020 DEBUG: Code 0 at UKb-R!zFS.iX#kwq&S$x:213130513
001003:0020 DEBUG: Code 590814 at UKb-R!zFS.iX#kwq&S$x:213129639
Butch Cassidy
Re: Butch Cassidy
Hi!
If, in fact, as your log indicates, this is an HD-DVD, be advised that there are VERY FEW HD-DVDs that MakeMKV is capable of fully processing...
Re: Butch Cassidy
Im confused now because the disc clearly looks like a Blu Ray. It says BluRay on it. Would an HD DVD even play on my blu ray player? Would they put an HDDVD movie on a Blu Ray disc?
Re: Butch Cassidy
Looks like I've misinterpreted the information generated in your log - your Pioneer drive is not capable of reading HD-DVDs (Plus a couple of lines later, the disc is identified as BD-ROM), so I'm now as perplexed as you are. Sorry...
- Contact:
Re: Butch Cassidy
The disc is physically damaged. You may try to increase IO retry count per http://www.makemkv.com/faq/item/7/catid/6 . Mac OS sometimes reports disc type incorrectly, hence the confusion with HD-DVD disc type.bigtoe wrote:002003:0000 Error 'Posix error - Input/output error' occured while reading 'DVD+R-DL PIONEER DVD-RW DVRTS08 Q81D' at offset '524288'
