UHD playback
Malachor
UHD playback
Post by Malachor » Sat Jan 12, 2019 11:52 pm
hey everyone,
ive had success ripping the UHD disks. but when i play it.. picture and sound looks good. one issue it seems to skip for a brief moment. just doesn't play smoothly.. i tried to find a fix.. i didn't see a post.. so i was looking for some help. im using windows 10. with 1080 gtx graphics card and 32 gbs of ram. im on the most current version of mkv . any help or advice would be greatly appreciated 8)
BlueMac77
Re: UHD playback
Post by BlueMac77 » Sun Jan 13, 2019 9:07 am
Malachor wrote: Sat Jan 12, 2019 11:52 pm hey everyone,
The skipping or jumpy playing problem might be on the type of player app you're using. Normally this problem happens with VLC player. There's a thread discussion here that you can look into
https://www.makemkv.com/forum/viewtopic ... 12&t=16883
You can also check out this player, https://mpv.io/ or https://mpc-hc.org/
