ive had success ripping the UHD disks. but when i play it.. picture and sound looks good. one issue it seems to skip for a brief moment. just doesn't play smoothly.. i tried to find a fix.. i didn't see a post.. so i was looking for some help. im using windows 10. with 1080 gtx graphics card and 32 gbs of ram. im on the most current version of mkv . any help or advice would be greatly appreciated
UHD playback
UHD playback
hey everyone,
Re: UHD playback
The skipping or jumpy playing problem might be on the type of player app you're using. Normally this problem happens with VLC player. There's a thread discussion here that you can look intoMalachor wrote: ↑Sat Jan 12, 2019 11:52 pmhey everyone,
ive had success ripping the UHD disks. but when i play it.. picture and sound looks good. one issue it seems to skip for a brief moment. just doesn't play smoothly.. i tried to find a fix.. i didn't see a post.. so i was looking for some help. im using windows 10. with 1080 gtx graphics card and 32 gbs of ram. im on the most current version of mkv . any help or advice would be greatly appreciated![]()
https://www.makemkv.com/forum/viewtopic ... 12&t=16883
You can also check out this player, https://mpv.io/ or https://mpc-hc.org/
