powdeau
Post by powdeau » Sat Jan 12, 2019 1:07 am
Thank you,
it is also working with encodes (I demux hevc file from encode + use original DV layer from Untouched BD). The only problem is that the encode is cropped because of black bars and this tool put in to the bottom of that DV layer, which has black bars. Is there any way to set it, so the encode in places in the middle of the second layer?
Post by Woodstock » Sat Jan 12, 2019 2:35 am
If you're encoding with handbrake, turn off auto cropping and set the cropping four values to zero. That will leave the letterboxing untouched, so it will remain centered.
dasefx
Post by dasefx » Sat Jan 12, 2019 3:11 am
Has anyone tried a movie that had a green tint in LG 2016 oled, but playable probably without it with sony x700?
Because someone else tried that with xbox, and it said that the TV DV version is too old
koalaman130
Post by koalaman130 » Sun Jan 20, 2019 5:09 am
Hey,
Sorry I am a noob to all this but I can seem to get this to even start to work.. I must be missing something. When I try to run mp4muxer it opens a command prompt window for a split second, then nothing. The same thing happens when I try using command prompt to open it, it does the same thing. If anyone has time to help, I would greatly appreciate it! I would really love to do some dv remuxes. Thank in advance!
olevelo
Post by olevelo » Mon Jan 21, 2019 6:34 pm
koalaman130 wrote: Sun Jan 20, 2019 5:09 am Hey,
You have to do it from a command prompt. It's command line driven. If you're in a command prompt, and navigate to the folder where it's at, you should be able to type the command line in. It shouldn't be closing the command prompt window on you.
powdeau
Post by powdeau » Tue Jan 22, 2019 2:08 am
I do it this way: I put all tracks into the bin folder, there (if you use Windows Explorer) I type "cmd" to the address bar (bar with folder path). Then I paste there the command from post 1.
ttringle
Post by ttringle » Wed Jan 23, 2019 11:58 pm
olevelo wrote: Sat Dec 29, 2018 11:33 pm You can say that not having lossless audio is a non-starter, but how is that any more important than not having DV at all?
Well at the moment I only have access to HDR10 via my Samsung. My next TV will have access to HDR10, HDR10+ and most like Dolby Vision and maybe HLG as well. But if I had to choose between Lossless Audio and DV over HDR10 + Lossless Audio then DV would lose out every time. Granted I have avoided being exposed to Dolby Vision because I currently do not have a DV capable TV but I would still take lossless audio. For me audio is as important as the picture. But that might change once I have DV but Audio is still a big part of why I ever upgrade at all.
TimT
olevelo
Post by olevelo » Thu Jan 24, 2019 2:45 am
ttringle wrote: Wed Jan 23, 2019 11:58 pm Well at the moment I only have access to HDR10 via my Samsung. My next TV will have access to HDR10, HDR10+ and most like Dolby Vision and maybe HLG as well. But if I had to choose between Lossless Audio and DV over HDR10 + Lossless Audio then DV would lose out every time. Granted I have avoided being exposed to Dolby Vision because I currently do not have a DV capable TV but I would still take lossless audio. For me audio is as important as the picture. But that might change once I have DV but Audio is still a big part of why I ever upgrade at all.
TimT
My point wasn't so much that one is more important than the other, but rather that they should both be important. If you're going to be one who insists on having the best by having lossless audio, why would you not also insist on having the best by having DV (or at least the option). I don't have an HDR10+ TV (and won't for quite awhile since I only just bought my LG OLED), but I would also argue for any capability to retain HDR10+ video as well, just as vehemently. The post I responded to originally said "what's the point?". If you don't get what the point is, then you should just be streaming off of Netflix. (granted, part of the argument was "what's the point of the current implementation without lossless audio", but that's not seeing the forest for the trees)
Grencola
Post by Grencola » Sun Jan 27, 2019 7:12 pm
never demux the ac3 track. it's crap. the best that mp4muxer supports is actually e-ac3 dolby digital plus 7.1 + atmos. it's still lossy, but at a much higher bitrate than regular ac3 (1536kbps vs 192kbps) and you get atmos (just like Netflix, etc). if you're lucky, some movies come with an eac3 dd+ 7.1 atmos track, but if not you have to do some converting. unfortunately only 5.1 (no atmos) is possible unless you have a licensed copy of dolby media encoder suite. usually movies only have hd-audio or dts/ac3 tracks though, so always pick the hd-audio track to demux. then use eac3to or ffmpeg to convert it to e-ac3, and create your mp4 with that. lossy dts-hd or true-hd dd+ e-ac3 sounds waay better than regular lossy dts or dd ac3.
powdeau wrote: Tue Jan 22, 2019 2:08 am I do it this way: I put all tracks into the bin folder, there (if you use Windows Explorer) I type "cmd" to the address bar (bar with folder path). Then I paste there the command from post 1.
even simpler, make this script:
open a new text file and paste in:
ren *.hevc baselayer.hevc
ren 0*.hevc dvlayer.hevc
ren *.ac3 audio.ac3
mp4muxer_64bits.exe --dv-profile 7 --input-file baselayer.hevc --input-file dvlayer.hevc --input-file audio.ac3 --media-lang eng --output-file movie.mp4
save it to where you keep your mp4muxer exe, and rename it to startmux.cmd
then whenever you're done demuxing a movie and converting audio, just place a copy of mp4muxer and startmux.cmd into your chosen demux folder and double click on startmux.cmd :)
Post by mike admin » Sun Jan 27, 2019 8:17 pm
By the way, MakeMKV supports on the fly DTS->AAC conversion...
jakeycrx
Post by jakeycrx » Mon Jan 28, 2019 1:02 pm
When trying to run the command line for MP4 muxer I get the error "sc miss-match"
Does anybody know what this means and how I get round it?
olevelo
Post by olevelo » Mon Jan 28, 2019 9:39 pm
Grencola wrote: Sun Jan 27, 2019 7:12 pm never demux the ac3 track. it's crap. the best that mp4muxer supports is actually e-ac3 dolby digital plus 7.1 + atmos. it's still lossy, but at a much higher bitrate than regular ac3 (1536kbps vs 192kbps) and you get atmos (just like Netflix, etc). if you're lucky, some movies come with an eac3 dd+ 7.1 atmos track, but if not you have to do some converting. unfortunately only 5.1 (no atmos) is possible unless you have a licensed copy of dolby media encoder suite. usually movies only have hd-audio or dts/ac3 tracks though, so always pick the hd-audio track to demux. then use eac3to or ffmpeg to convert it to e-ac3, and create your mp4 with that. lossy dts-hd or true-hd dd+ e-ac3 sounds waay better than regular lossy dts or dd ac3.
You seem to be talking out of both sides. You say don't demux the ac3 track, but then you admit that most movies don't have a DD+ track to demux directly. Then you say to demux the HD audio and convert it to e-ac3, but before that you admit that without a licensed dolby encoder, you can only get non-Atmos 5.1...so what's the point of converting when you can just demux the ac3 track? The one that's created by the movie makers is likely to be as good as or better than one that you create from converting from one format to another.
Grencola
Post by Grencola » Mon Jan 28, 2019 11:59 pm
olevelo wrote: Mon Jan 28, 2019 9:39 pm
Lol what? read what I said again. I said to never demux the ac3 track, cuz it's crap. I said if you're lucky there's an eac3 7.1 track sometimes on the movie. I said otherwise it's just hd audio / ac3. I said to always choose the hd audio track and convert it to eac3. I said eac3 5.1 is all you can get without using dolby tools. I never said once to convert it to ac3 5.1, there's a big difference. I said the bitrate will be much higher with eac3 and that also dd+ sounds better than regular dd. google ac3 vs eac3 if you still don't understand.
olevelo
Post by olevelo » Tue Jan 29, 2019 1:20 am
Grencola wrote: Mon Jan 28, 2019 11:59 pm Lol what? read what I said again. I said to never demux the ac3 track, cuz it's crap. I said if you're lucky there's an eac3 7.1 track sometimes on the movie. I said otherwise it's just hd audio / ac3. I said to always choose the hd audio track and convert it to eac3. I said eac3 5.1 is all you can get without using dolby tools. I never said once to convert it to ac3 5.1, there's a big difference. I said the bitrate will be much higher with eac3 and that also dd+ sounds better than regular dd. google ac3 vs eac3 if you still don't understand.
I know exactly what you said, because I already repeated it, then you repeated it again. From what I've seen, there is very little difference in an AC-3 and an E-AC-3 track, unless you're able to encode the extra channels or Atmos into the E-AC-3. If there is a substantial difference, please educate us. In addition, even before you said this, I had tried to convert my TrueHD tracks to E-AC-3 but I couldn't find any tools which could do it. The only one that even claimed to do it was XMedia Recode (actually from your comment on the Reddit post awhile back), but it just produces a silent 10 second or so file. Nothing I did worked. If you could share some details on how to convert to eac3 properly I'd love to hear it.
Grencola
Post by Grencola » Tue Jan 29, 2019 4:01 am
heh alright then. yea for sure I can help, XMedia Recode works well. like I said the eac3 file I create from hd-audio has 1536kbps vs the196kbps ac3 file. that's a huge difference :) demux the hd-audio track, let's use dts-hd for example, in TSMuxer (don't select down-convert) which spits out a .dts file (you've obviously done this part already). then add the dts file into XMedia Recode, and then on the preset pull down choose custom and find e-ac3 from the big list. then on the pulldown that says stereo choose 5.1 (front left, front right, center, side left, side right (cuz rear left and rear right is for 7.1), I believe it's the 2nd from the bottom. then under bitrate pulldown choose the largest one at the end (1536kbps), then click add to queue and hit encode. it'll produce a new dts file but this time it has the original dts track, and the new dd+ eac3 track you created. add this new dts file back into tsmuxer and demux one last time. it will split them apart and you'll get an ac3 file, which when you check the media info will show dd+ eac3 1536kbps that plays great.
