New User
bull77ock
New User
#1 Post by bull77ock » Fri Jan 11, 2019 6:35 pm
I paid for the latest version and have been using it for weeks. No issues at all. But, I had to shutdown my computer and when the system came back, the MakeMKV icon was changed from its logo to a question mark. I have to go back to the package and click on the MakeMKV icon in the folder and it loads. I tested it, and it only does it when I shut down or restart my iMac.
I am sure I am doing something wrong, but could somebody point me in the right direction to keep the app installed.
I am running Mojave if that makes a difference.
Thanks in advance.
Bob
Lovely Rita
Re: New User
#2 Post by Lovely Rita » Sat Jan 12, 2019 12:31 am
Sounds like you need to install the app, properly.
Once the package/folder opens drag the app to the Applications folder.
Registered User :wink:
Buy MakeMKV
T'hain Esh Kelch
Re: New User
#3 Post by T'hain Esh Kelch » Mon Jan 14, 2019 12:58 pm
You are running the app from a virtual disk image, which is why it disappears, as the virtual disc becomes unmounted upon system shut down.
Solution: Copy the binary to your application folder.
Also, please provide a proper title next time you create a thread.
