Hello
I've read the "read this before posting thread" But I'm not sure what to do.
Maybe its not rippable, but I hope there is a fix.
It manage to do 100%, but then it fails to save the file as mkv I think.
Ive never experienced this with a disc before, Ive ripped nearly a thousand movies.
MakeMKV v1.14.2 darwin(x64-release) started
Optical drive "BD-ROM ASUS SBC-06D2X-U D201d" opened in OS access mode.
Loaded 29 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 1 clip(s)
File 00500.mpls was added as title #0
File 00519.mpls was added as title #1
File 00520.mpls was added as title #2
Title #00020.mpls has length of 87 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title 00800.mpls is equal to title 00500.mpls and was skipped
Title 00850.mpls is equal to title 00500.mpls and was skipped
Title 00319.mpls is equal to title 00519.mpls and was skipped
Title 00320.mpls is equal to title 00520.mpls and was skipped
Title #00339.mpls(1) has length of 308 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00412.mpls has length of 54 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00413.mpls has length of 31 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00415.mpls has length of 27 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00440.mpls has length of 83 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00416.mpls has length of 19 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00417.mpls has length of 46 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00418.mpls has length of 31 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00419.mpls has length of 51 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00420.mpls has length of 87 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00421.mpls has length of 27 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00422.mpls has length of 51 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00423.mpls has length of 43 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00424.mpls has length of 27 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00426.mpls has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00427.mpls has length of 16 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00428.mpls has length of 12 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00429.mpls has length of 68 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00431.mpls has length of 16 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00432.mpls has length of 16 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00433.mpls has length of 36 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00434.mpls has length of 72 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00435.mpls has length of 12 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00436.mpls has length of 36 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00437.mpls has length of 28 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00438.mpls has length of 12 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00021.mpls has length of 87 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00305.mpls has length of 92 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00307.mpls has length of 353 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00308.mpls has length of 128 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00011.m2ts has length of 23 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00122.m2ts has length of 11 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00123.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00720.m2ts has length of 17 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00501.m2ts has length of 277 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00502.m2ts has length of 465 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00503.m2ts has length of 183 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00504.m2ts has length of 84 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00509.m2ts has length of 78 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00510.m2ts has length of 118 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00511.m2ts has length of 144 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00512.m2ts has length of 45 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00513.m2ts has length of 188 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00514.m2ts has length of 89 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00753.m2ts has length of 89 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00515.m2ts has length of 111 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00754.m2ts has length of 111 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00521.m2ts has length of 272 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00322.m2ts has length of 174 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00523.m2ts has length of 268 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00524.m2ts has length of 89 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00525.m2ts has length of 89 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00526.m2ts has length of 32 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00748.m2ts has length of 91 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00750.m2ts has length of 32 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00751.m2ts has length of 32 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00752.m2ts has length of 32 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00755.m2ts has length of 0 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00020.m2ts has length of 57 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00021.m2ts has length of 29 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00541.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00542.m2ts has length of 30 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00543.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00545.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00547.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00548.m2ts has length of 68 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00549.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00550.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00551.m2ts has length of 30 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00552.m2ts has length of 16 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00553.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00546.m2ts has length of 12 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00554.m2ts has length of 16 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00555.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00556.m2ts has length of 36 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00558.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00747.m2ts has length of 72 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00559.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00560.m2ts has length of 12 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00561.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00562.m2ts has length of 36 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00563.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00564.m2ts has length of 28 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00565.m2ts has length of 15 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00566.m2ts has length of 12 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00568.m2ts has length of 16 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00569.m2ts has length of 24 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00570.m2ts has length of 4 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00022.m2ts has length of 57 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #00023.m2ts has length of 29 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Saving 1 titles into directory /Users/brukernmin/Movies
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00500.m2ts' at offset '27468300288'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '27468300288'
Failed to save title 0 to file /Users/brukernmin/Movies/A VIEW TO A KILL_t00.mkv
Encountered 32 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
Error ripping James Bond (A View to a Kill)
Re: Error ripping James Bond (A View to a Kill)
Your drive is having trouble reading the disk when it spins up to high speed; it is simply running out of power.
Is it plugged directly into the computer, into a powered USB hub, or an un-powered USB hub?
savannen
Directly into my macbook pro with usb. Its usb-powered only.
Is the Mac plugged in or running on battery?
If it's plugged in, there SHOULD be enough power to run the drive at full speed, although I think Asus provided a 2-head cable to give it access to "2 units" of USB power.
The way to limit the speed is to write to a destination that can't accept data at the same rate MakeMKV can pull it from the disk. I've tested using a USB 2.0 flash drive as the target, and it keeps the optical drive slowed to 4-6x read speeds, which is usually within the power limit of a single (powered) USB port. The caveat is that the USB flash drive has to be big enough to take the contents, and formatted in either ExFAT (Mac or Windows) or NTFS (Windows and Linux).
