#496
Post
by d00zah » Thu Jan 03, 2019 1:56 pm
Malkana wrote: Thu Jan 03, 2019 1:08 pm
Fudgemaster3000 wrote: Mon Dec 31, 2018 1:27 am
Sorry for the double post, I was actually able to get the automatic tool to prepare the proper 3.02 firmware. Everything is working Perfectly!!! Thank you all for your post and instructions.
What do you mean by "automatic tool"?
1st post in this thread...
https://www.makemkv.com/forum/viewtopic ... 058#p60312
Steps for importing data from backup firmwares : (Automatic Method)
Unzip the
EEPROM Data Mover attached below.
Open it, select first the dumped original firmware.
Select now a clean firmware to insert data (clean firmwares can be found here).
Type now a firmware name (i.e. TEST.BIN) which will be the one you will eventually need to flash on your drive.
gonenutsbrb
#497
Post
by gonenutsbrb » Sat Jan 05, 2019 12:47 am
Just did this method with by BW-16D1HT. Worked perfectly.
DOSFLASH on FreeDOS dump, to EEPROM Mover, to DOSFLASH erase, then DOSFLASH write.
I'm on 3.01 and reading UHD as we speak.
Quick question though, I re-purposed the enclosure from my ASUS BW-16D1X-U. So now I have a Pioneer drive with Asus firmware on it, and printed right on the front of the dang thing is BDXL. Is there anyone who has tried to write different firmware on this one to support reading UHD? Otherwise, I'll probably just sell it on CL.
Thanks for the great guide!
#498
Post
by Billycar11 » Sat Jan 05, 2019 7:15 am
gonenutsbrb wrote: Sat Jan 05, 2019 12:47 am
just sell it or use it for regular blurays
#499
Post
by Woodstock » Sat Jan 05, 2019 2:11 pm
There are two levels of BDXL. The initial level is "more layers"; the higher level is "higher bit-rate on each layer".
UHD uses both the extra layers and the higher bit rate, which early BDXL drives cannot do. The LG drives signify the higher level via the "SVC CODE" being NS50 or higher.
classek
#500
Post
by classek » Sun Jan 06, 2019 8:28 pm
Hi everyone. I used the Windows Method up until step 7 for dumping the 1.03 firmware that came with my ASUS BW-16D1HT drive. Would someone please create the downgraded firmware for the drive. I have attached the 1.03 firmware dump of my drive.
Thank you,
- asusflash103.zip
- (1.29 MiB) Downloaded 1296 times
zuluzkiller
#501
Post
by zuluzkiller » Sun Jan 06, 2019 10:05 pm
I purchased Asus BW-16D1HT recently and it came with firmware 3.03, manufactured May 2018.
I'm following TeddyRaspin guide and managed to save original firmware with DOSFLASH32_BH16NS40.exe. and then again with DOSFLASH.zip. I'm kind of stuck at Hex editing part, I was wondering if I provide two of my firmware backups, could someone create for me new firmware file based on clean (I have those too) Asus firmware, either 3.01 or 3.02, so I can red UHD disks?
badtzhk88
#502
Post
by badtzhk88 » Mon Jan 07, 2019 3:42 am
Mine is ASUS BW-16D1HT
Firmware 1.0.1
BH16NS60/50 Flash Chip
I have dump the flash
Anything I should do ?
Upgrade to 3.0.1 ?
Thanks for any comment
- asusfalsh101.zip
- (1.16 MiB) Downloaded 1466 times
- BW-16d1HT.jpg (233.54 KiB) Viewed 39781 times
#503
Post
by Billycar11 » Mon Jan 07, 2019 4:07 am
badtzhk88 wrote: Mon Jan 07, 2019 3:42 am
Firmware 1.0.1
Upgrade to 3.0.1 ?
to old if it came with 1.xx firmware needs 3.00+ and 2015+ build date
st4evr
#504
Post
by st4evr » Mon Jan 07, 2019 4:15 am
Firmware 1.0.1
Upgrade to 3.0.1 ?
Simple. Buy a new UHD Friendly drive. That drive is too old. Asus 1.0 firmware drives predate UHD compatability by several years. If you attempt an update to newer 3.0+ firmware you’ll brick the drive and simply end up with a nice paperweight or doorstop.
#505
Post
by MartyMcNuts » Mon Jan 07, 2019 4:27 am
classek wrote: Sun Jan 06, 2019 8:28 pm
Thank you,
classek,
I assume you mean your's came with fw 3.03??
Anyway, here is an ASUS 3.02 created using your dump. Let us know how you go..
zuluzkiller
#506
Post
by zuluzkiller » Mon Jan 07, 2019 12:25 pm
zuluzkiller wrote: Sun Jan 06, 2019 10:05 pm
I ended up using EEPROM data mover to create new firmware file then flash my drive. On first try, I got drive saying that firmware level was BOOT and it would not open it's door, so I tried again and got it to 3.01. Driver works, it will read DVD/BD etc. but it still won't read UHD disks. When you insert UHD disk, it spins up, makes this weird seeking sound for a while like is trying to read it but then it stops and that is it.
platinumjsi
#507
Post
by platinumjsi » Tue Jan 08, 2019 9:53 am
Hey TeddyRaspin are you still able to do downgrades? I sent you a PM but for some reason its stuck in my outbox.
I have grabbed the ROM from my drive but I am not confident with the Hex editor
#508
Post
by Billycar11 » Tue Jan 08, 2019 10:07 am
platinumjsi wrote: Tue Jan 08, 2019 9:53 am
He posted along time ago he is not doing it anymore there is a tool on first page eeprom data mover use that, if not post it here I or someone else will edit it for you
platinumjsi
#509
Post
by platinumjsi » Tue Jan 08, 2019 10:24 am
Ok I had a look at it and wasn't confident if someone else would be able to create me a rom that would be much appreciated, I can send over the rom I pulled from the drive.
#510
Post
by Billycar11 » Tue Jan 08, 2019 10:42 am
platinumjsi wrote: Tue Jan 08, 2019 10:24 am
Sure if you don't want to put it here email it to me
billycar5924@gmail.com
