I am having an issue with Other People's Money the dvd gets to the same spot and stops. I am not sophisticated enough to work through the manual process.
I also seem to have an issue with warner brothers dvds both bluray as well as standard dvds with errors in the middle that do not stop recording but cause jumps in the middle of the movie.
I have attached the debug code for Other People's Money in the hopes someone could help me get past the error.
MakeMKV v1.14.2 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\../MakeMKV_log.txt
Title #1 was added (23 cell(s), 1:40:39)
Title #2 has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
Title #3 has length of 21 seconds which is less than minimum title length of 90 seconds and was therefore skipped
Title #4 has length of 7 seconds which is less than minimum title length of 90 seconds and was therefore skipped
Title #5 has length of 29 seconds which is less than minimum title length of 90 seconds and was therefore skipped
Title #6 has length of 88 seconds which is less than minimum title length of 90 seconds and was therefore skipped
Title #7 has length of 12 seconds which is less than minimum title length of 90 seconds and was therefore skipped
Title #8 was added (1 cell(s), 0:01:59)
Subtitle stream #3 is identical to stream #2 and was skipped
Subtitle stream #4 is identical to stream #2 and was skipped
Saving 1 titles into directory /dvd/OTHER PEOPLES MONEY
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1332289536'
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom0' at offset '1332289536'
DEBUG: Code 3221225861 at Gn,QlSs)zv!z6u9zh1:29395080
DEBUG: Code 100941314 at Gn,QlSs)zv!z6u9zh1:29395080
DEBUG: Code 0 at }vFN@KpabQ2CK7z+-/iZ:29395011
DEBUG: Code 0 at %1BDrSLv=Ag ^\$eP<K:213129915
DEBUG: Code 0 at }vFN@KpabQ2CK7z+-/iZ:29394459
DEBUG: Code 650532 at }vFN@KpabQ2CK7z+-/iZ:29393286
Error 'OS error - The specified request is not a valid operation for the target device' occurred while reading '\Device\CdRom0' at offset '1332289536'
DEBUG: Code 3221225488 at Gn,QlSs)zv!z6u9zh1:29395080
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1332289536'
DEBUG: Code 101000192 at Gn,QlSs)zv!z6u9zh1:29395080
DEBUG: Code 0 at Si0V5Sd:mgl|*kGOu<s]#:213136608
DEBUG: Code 0 at }v9S<}>On\hMdk[orLS,:29394022
DEBUG: Code 0 at }v9S<}>On\hMdk[orLS,:213140840
DEBUG: Code 0 at }v9S<}>On\hMdk[orLS,:29404556
DEBUG: Code 0 at }v9S<}>On\hMdk[orLS,:213139506
DEBUG: Code 1 at l6^_w`bC)?2^kDMI:29395195
DEBUG: Code 0 at l6^_w`bC)?2^kDMI:29397058
DEBUG: Code 0 at }vFN@KpabQ2CK7z+-/iZ:29393286
Failed to save title 0 to file /dvd/OTHER PEOPLES MONEY/OTHER PEOPLES MONEY.mkv
Encountered 12 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Warner Brothers
Re: Warner Brothers
Your drive is reaching a spot it cannot read, and tries repeatedly to do so. While it is doing that, Windows times out waiting for it, and declares the drive "offline" for a while.
Try cleaning the disk and see if the issue goes away - there's a topic in the Bluray section on dealing with read errors like this.
