titles extract without issue but disc backups corrupt
corruption
Post by corruption »
I've read the hashcheck error help page which says it's likely a failing drive. I'm certainly open to this possibility, but I'm confused as to why I can still pull all the titles into MKVs and they play fine, while trying to backup a disc results in hashcheck errors. How can I pull the MKVs if my drive is failing? (serious question)
Hoping there's something more at work here:
Asus BC-12b1st B3.00
MakeMKV 1.14.2
The Dark Tower
Atomic Blonde
Ready Player One
Hash check failed for file 00641.m2ts at offset 190464, file is corrupt.
Hash check for /BDMV/STREAM/00641.m2ts : 84.21% corrupt, 0% correct, 84.21% checked.
Hash check failed for file 00644.m2ts at offset 190464, file is corrupt.
Hash check for /BDMV/STREAM/00644.m2ts : 84.21% corrupt, 0% correct, 84.21% checked.
Hash check failed for file 00642.m2ts at offset 190464, file is corrupt.
Hash check for /BDMV/STREAM/00642.m2ts : 84.21% corrupt, 0% correct, 84.21% checked.
Hash check failed for file 00643.m2ts at offset 190464, file is corrupt.
Hash check for /BDMV/STREAM/00643.m2ts : 84.21% corrupt, 0% correct, 84.21% checked.
Hash check failed for file 00082.m2ts at offset 190464, file is corrupt.
Hash check for /BDMV/STREAM/00082.m2ts : 52.45% corrupt, 0% correct, 52.45% checked.
Hash check failed for file 00104.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00104.m2ts at offset 387072, file is corrupt.
Hash check for /BDMV/STREAM/00104.m2ts : 82.05% corrupt, 0% correct, 82.05% checked.
Hash check failed for file 00602.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00602.m2ts at offset 387072, file is corrupt.
Hash check for /BDMV/STREAM/00602.m2ts : 68.08% corrupt, 0% correct, 68.08% checked.
Hash check failed for file 00601.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00601.m2ts at offset 387072, file is corrupt.
Hash check for /BDMV/STREAM/00601.m2ts : 68.08% corrupt, 0% correct, 68.08% checked.
Hash check failed for file 00679.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00679.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00679.m2ts at offset 583680, file is corrupt.
Hash check for /BDMV/STREAM/00679.m2ts : 88.07% corrupt, 0% correct, 88.07% checked.
Hash check failed for file 00080.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00080.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00080.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00080.m2ts at offset 780288, file is corrupt.
Hash check for /BDMV/STREAM/00080.m2ts : 100% corrupt, 0% correct, 100% checked.
Hash check failed for file 00678.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00678.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00678.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00678.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00678.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00678.m2ts.
Hash check for /BDMV/STREAM/00678.m2ts : 97.56% corrupt, 0% correct, 97.56% checked.
Hash check failed for file 00671.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00671.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00671.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00671.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00671.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00671.m2ts.
Hash check for /BDMV/STREAM/00671.m2ts : 95.80% corrupt, 0% correct, 95.80% checked.
Hash check failed for file 00700.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00700.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00700.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00700.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00700.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00700.m2ts.
Hash check for /BDMV/STREAM/00700.m2ts : 85.56% corrupt, 0% correct, 85.56% checked.
Hash check failed for file 00081.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00081.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00081.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00081.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00081.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00081.m2ts.
Hash check for /BDMV/STREAM/00081.m2ts : 99.55% corrupt, 0% correct, 99.55% checked.
Hash check failed for file 00658.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00658.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00658.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00658.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00658.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00658.m2ts.
Hash check for /BDMV/STREAM/00658.m2ts : 89.95% corrupt, 0% correct, 89.95% checked.
Hash check failed for file 00657.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00657.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00657.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00657.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00657.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00657.m2ts.
Hash check for /BDMV/STREAM/00657.m2ts : 89.95% corrupt, 0% correct, 89.95% checked.
Hash check failed for file 00682.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00682.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00682.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00682.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00682.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00682.m2ts.
Hash check for /BDMV/STREAM/00682.m2ts : 89.60% corrupt, 0% correct, 89.60% checked.
Hash check failed for file 00699.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00699.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00699.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00699.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00699.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00699.m2ts.
Hash check for /BDMV/STREAM/00699.m2ts : 88.18% corrupt, 0% correct, 88.18% checked.
Hash check failed for file 00673.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00673.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00673.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00673.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00673.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00673.m2ts.
Hash check for /BDMV/STREAM/00673.m2ts : 100% corrupt, 0% correct, 100% checked.
Hash check failed for file 00667.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00667.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00667.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00667.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00667.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00667.m2ts.
Hash check for /BDMV/STREAM/00667.m2ts : 98.08% corrupt, 0% correct, 98.08% checked.
Hash check failed for file 00675.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00675.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00675.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00675.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00675.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00675.m2ts.
Hash check for /BDMV/STREAM/00675.m2ts : 95.52% corrupt, 0% correct, 95.52% checked.
Hash check failed for file 00664.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00664.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00664.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00664.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00664.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00664.m2ts.
Hash check for /BDMV/STREAM/00664.m2ts : 92.41% corrupt, 0% correct, 92.41% checked.
Hash check failed for file 00600.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00600.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00600.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00600.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00600.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00600.m2ts.
Hash check for /BDMV/STREAM/00600.m2ts : 90.45% corrupt, 0% correct, 90.45% checked.
Hash check failed for file 00693.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00693.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00693.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00693.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00693.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00693.m2ts.
Hash check for /BDMV/STREAM/00693.m2ts : 89.51% corrupt, 0% correct, 89.51% checked.
Hash check failed for file 00692.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00692.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00692.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00692.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00692.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00692.m2ts.
Hash check for /BDMV/STREAM/00692.m2ts : 97.62% corrupt, 0% correct, 97.62% checked.
Hash check failed for file 00694.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00694.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00694.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00694.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00694.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00694.m2ts.
Hash check for /BDMV/STREAM/00694.m2ts : 96.64% corrupt, 0% correct, 96.64% checked.
Hash check failed for file 00674.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00674.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00674.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00674.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00674.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00674.m2ts.
Hash check for /BDMV/STREAM/00674.m2ts : 95.36% corrupt, 0% correct, 95.36% checked.
Hash check failed for file 00670.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00670.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00670.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00670.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00670.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00670.m2ts.
Hash check for /BDMV/STREAM/00670.m2ts : 94.11% corrupt, 0% correct, 94.11% checked.
Hash check failed for file 00666.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00666.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00666.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00666.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00666.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00666.m2ts.
Hash check for /BDMV/STREAM/00666.m2ts : 92.60% corrupt, 0% correct, 92.60% checked.
Hash check failed for file 00697.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00697.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00697.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00697.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00697.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00697.m2ts.
Hash check for /BDMV/STREAM/00697.m2ts : 92.30% corrupt, 0% correct, 92.30% checked.
Hash check failed for file 00676.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00676.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00676.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00676.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00676.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00676.m2ts.
Hash check for /BDMV/STREAM/00676.m2ts : 91.13% corrupt, 0% correct, 91.13% checked.
Hash check failed for file 00672.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00672.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00672.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00672.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00672.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00672.m2ts.
Hash check for /BDMV/STREAM/00672.m2ts : 96.96% corrupt, 0% correct, 96.96% checked.
Hash check failed for file 00685.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00685.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00685.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00685.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00685.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00685.m2ts.
Hash check for /BDMV/STREAM/00685.m2ts : 94.95% corrupt, 0% correct, 94.95% checked.
Hash check failed for file 00603.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00603.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00603.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00603.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00603.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00603.m2ts.
Hash check for /BDMV/STREAM/00603.m2ts : 93.84% corrupt, 0% correct, 93.84% checked.
Hash check failed for file 00632.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00632.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00632.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00632.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00632.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00632.m2ts.
Hash check for /BDMV/STREAM/00632.m2ts : 93.29% corrupt, 0% correct, 93.29% checked.
Hash check failed for file 00677.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00677.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00677.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00677.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00677.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00677.m2ts.
Hash check for /BDMV/STREAM/00677.m2ts : 91.42% corrupt, 0% correct, 91.42% checked.
Hash check failed for file 00696.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00696.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00696.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00696.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00696.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00696.m2ts.
Hash check for /BDMV/STREAM/00696.m2ts : 91.42% corrupt, 0% correct, 91.42% checked.
Hash check failed for file 00660.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00660.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00660.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00660.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00660.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00660.m2ts.
Hash check for /BDMV/STREAM/00660.m2ts : 99.43% corrupt, 0% correct, 99.43% checked.
Hash check failed for file 00648.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00648.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00648.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00648.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00648.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00648.m2ts.
Hash check for /BDMV/STREAM/00648.m2ts : 99.15% corrupt, 0% correct, 99.15% checked.
Hash check failed for file 00686.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00686.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00686.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00686.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00686.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00686.m2ts.
Hash check for /BDMV/STREAM/00686.m2ts : 97.77% corrupt, 0% correct, 97.77% checked.
Hash check failed for file 00684.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00684.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00684.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00684.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00684.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00684.m2ts.
Hash check for /BDMV/STREAM/00684.m2ts : 97.50% corrupt, 0% correct, 97.50% checked.
Hash check failed for file 00640.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00640.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00640.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00640.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00640.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00640.m2ts.
Hash check for /BDMV/STREAM/00640.m2ts : 96.43% corrupt, 0% correct, 96.43% checked.
Hash check failed for file 00668.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00668.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00668.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00668.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00668.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00668.m2ts.
Hash check for /BDMV/STREAM/00668.m2ts : 95.91% corrupt, 0% correct, 95.91% checked.
Hash check failed for file 00669.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00669.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00669.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00669.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00669.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00669.m2ts.
Hash check for /BDMV/STREAM/00669.m2ts : 95.91% corrupt, 0% correct, 95.91% checked.
Hash check failed for file 00695.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00695.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00695.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00695.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00695.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00695.m2ts.
Hash check for /BDMV/STREAM/00695.m2ts : 95.91% corrupt, 0% correct, 95.91% checked.
Hash check failed for file 00639.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00639.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00639.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00639.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00639.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00639.m2ts.
Hash check for /BDMV/STREAM/00639.m2ts : 95.65% corrupt, 0% correct, 95.65% checked.
Hash check failed for file 00659.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00659.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00659.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00659.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00659.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00659.m2ts.
Hash check for /BDMV/STREAM/00659.m2ts : 94.87% corrupt, 0% correct, 94.87% checked.
Hash check failed for file 00634.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00634.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00634.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00634.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00634.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00634.m2ts.
Hash check for /BDMV/STREAM/00634.m2ts : 94.36% corrupt, 0% correct, 94.36% checked.
Hash check failed for file 00662.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00662.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00662.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00662.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00662.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00662.m2ts.
Hash check for /BDMV/STREAM/00662.m2ts : 94.36% corrupt, 0% correct, 94.36% checked.
Hash check failed for file 00681.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00681.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00681.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00681.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00681.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00681.m2ts.
Hash check for /BDMV/STREAM/00681.m2ts : 93.61% corrupt, 0% correct, 93.61% checked.
Hash check failed for file 00656.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00656.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00656.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00656.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00656.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00656.m2ts.
Hash check for /BDMV/STREAM/00656.m2ts : 99.74% corrupt, 0% correct, 99.74% checked.
Hash check failed for file 00661.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00661.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00661.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00661.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00661.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00661.m2ts.
Hash check for /BDMV/STREAM/00661.m2ts : 96.72% corrupt, 0% correct, 96.72% checked.
Hash check failed for file 00630.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00630.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00630.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00630.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00630.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00630.m2ts.
Hash check for /BDMV/STREAM/00630.m2ts : 96.00% corrupt, 0% correct, 96.00% checked.
Hash check failed for file 00616.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00616.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00616.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00616.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00616.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00616.m2ts.
Hash check for /BDMV/STREAM/00616.m2ts : 96.00% corrupt, 0% correct, 96.00% checked.
Hash check failed for file 00637.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00637.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00637.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00637.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00637.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00637.m2ts.
Hash check for /BDMV/STREAM/00637.m2ts : 94.34% corrupt, 0% correct, 94.34% checked.
Hash check failed for file 00665.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00665.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00665.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00665.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00665.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00665.m2ts.
Hash check for /BDMV/STREAM/00665.m2ts : 92.97% corrupt, 0% correct, 92.97% checked.
Hash check failed for file 00635.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00635.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00635.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00635.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00635.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00635.m2ts.
Hash check for /BDMV/STREAM/00635.m2ts : 99.76% corrupt, 0% correct, 99.76% checked.
Hash check failed for file 00636.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00636.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00636.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00636.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00636.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00636.m2ts.
Hash check for /BDMV/STREAM/00636.m2ts : 99.28% corrupt, 0% correct, 99.28% checked.
Hash check failed for file 00607.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00607.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00607.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00607.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00607.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00607.m2ts.
Hash check for /BDMV/STREAM/00607.m2ts : 98.34% corrupt, 0% correct, 98.34% checked.
Hash check failed for file 00621.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00621.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00621.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00621.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00621.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00621.m2ts.
Hash check for /BDMV/STREAM/00621.m2ts : 98.34% corrupt, 0% correct, 98.34% checked.
Hash check failed for file 00625.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00625.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00625.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00625.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00625.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00625.m2ts.
Hash check for /BDMV/STREAM/00625.m2ts : 97.65% corrupt, 0% correct, 97.65% checked.
Hash check failed for file 00611.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00611.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00611.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00611.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00611.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00611.m2ts.
Hash check for /BDMV/STREAM/00611.m2ts : 97.65% corrupt, 0% correct, 97.65% checked.
Hash check failed for file 00698.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00698.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00698.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00698.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00698.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00698.m2ts.
Hash check for /BDMV/STREAM/00698.m2ts : 94.97% corrupt, 0% correct, 94.97% checked.
Hash check failed for file 00654.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00654.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00654.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00654.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00654.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00654.m2ts.
Hash check for /BDMV/STREAM/00654.m2ts : 93.69% corrupt, 0% correct, 93.69% checked.
Hash check failed for file 00646.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00646.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00646.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00646.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00646.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00646.m2ts.
Hash check for /BDMV/STREAM/00646.m2ts : 99.77% corrupt, 0% correct, 99.77% checked.
Hash check failed for file 00645.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00645.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00645.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00645.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00645.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00645.m2ts.
Hash check for /BDMV/STREAM/00645.m2ts : 96.76% corrupt, 0% correct, 96.76% checked.
Hash check failed for file 00683.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00683.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00683.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00683.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00683.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00683.m2ts.
Hash check for /BDMV/STREAM/00683.m2ts : 94.71% corrupt, 0% correct, 94.71% checked.
Hash check failed for file 00638.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00638.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00638.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00638.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00638.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00638.m2ts.
Hash check for /BDMV/STREAM/00638.m2ts : 94.31% corrupt, 0% correct, 94.31% checked.
Hash check failed for file 00649.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00649.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00649.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00649.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00649.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00649.m2ts.
Hash check for /BDMV/STREAM/00649.m2ts : 98.08% corrupt, 0% correct, 98.08% checked.
Hash check failed for file 00606.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00606.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00606.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00606.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00606.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00606.m2ts.
Hash check for /BDMV/STREAM/00606.m2ts : 97.15% corrupt, 0% correct, 97.15% checked.
Hash check failed for file 00620.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00620.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00620.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00620.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00620.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00620.m2ts.
Hash check for /BDMV/STREAM/00620.m2ts : 97.15% corrupt, 0% correct, 97.15% checked.
Hash check failed for file 00623.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00623.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00623.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00623.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00623.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00623.m2ts.
Hash check for /BDMV/STREAM/00623.m2ts : 95.70% corrupt, 0% correct, 95.70% checked.
Hash check failed for file 00609.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00609.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00609.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00609.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00609.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00609.m2ts.
Hash check for /BDMV/STREAM/00609.m2ts : 95.70% corrupt, 0% correct, 95.70% checked.
Hash check failed for file 00653.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00653.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00653.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00653.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00653.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00653.m2ts.
Hash check for /BDMV/STREAM/00653.m2ts : 98.37% corrupt, 0% correct, 98.37% checked.
Hash check failed for file 00628.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00628.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00628.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00628.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00628.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00628.m2ts.
Hash check for /BDMV/STREAM/00628.m2ts : 97.49% corrupt, 0% correct, 97.49% checked.
Hash check failed for file 00614.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00614.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00614.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00614.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00614.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00614.m2ts.
Hash check for /BDMV/STREAM/00614.m2ts : 97.49% corrupt, 0% correct, 97.49% checked.
Hash check failed for file 00633.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00633.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00633.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00633.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00633.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00633.m2ts.
Hash check for /BDMV/STREAM/00633.m2ts : 96.62% corrupt, 0% correct, 96.62% checked.
Hash check failed for file 00650.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00650.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00650.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00650.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00650.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00650.m2ts.
Hash check for /BDMV/STREAM/00650.m2ts : 96.11% corrupt, 0% correct, 96.11% checked.
Hash check failed for file 00680.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00680.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00680.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00680.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00680.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00680.m2ts.
Hash check for /BDMV/STREAM/00680.m2ts : 99.31% corrupt, 0% correct, 99.31% checked.
Hash check failed for file 00687.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00687.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00687.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00687.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00687.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00687.m2ts.
Hash check for /BDMV/STREAM/00687.m2ts : 99.31% corrupt, 0% correct, 99.31% checked.
Hash check failed for file 00663.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00663.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00663.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00663.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00663.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00663.m2ts.
Hash check for /BDMV/STREAM/00663.m2ts : 98.22% corrupt, 0% correct, 98.22% checked.
Hash check failed for file 00652.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00652.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00652.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00652.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00652.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00652.m2ts.
Hash check for /BDMV/STREAM/00652.m2ts : 98.53% corrupt, 0% correct, 98.53% checked.
Hash check failed for file 00651.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00651.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00651.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00651.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00651.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00651.m2ts.
Hash check for /BDMV/STREAM/00651.m2ts : 96.96% corrupt, 0% correct, 96.96% checked.
Hash check failed for file 00631.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00631.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00631.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00631.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00631.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00631.m2ts.
Hash check for /BDMV/STREAM/00631.m2ts : 99.85% corrupt, 0% correct, 99.85% checked.
Hash check failed for file 00617.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00617.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00617.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00617.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00617.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00617.m2ts.
Hash check for /BDMV/STREAM/00617.m2ts : 99.85% corrupt, 0% correct, 99.85% checked.
Hash check failed for file 00613.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00613.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00613.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00613.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00613.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00613.m2ts.
Hash check for /BDMV/STREAM/00613.m2ts : 96.57% corrupt, 0% correct, 96.57% checked.
Hash check failed for file 00627.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00627.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00627.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00627.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00627.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00627.m2ts.
Hash check for /BDMV/STREAM/00627.m2ts : 96.57% corrupt, 0% correct, 96.57% checked.
Hash check failed for file 00622.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00622.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00622.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00622.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00622.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00622.m2ts.
Hash check for /BDMV/STREAM/00622.m2ts : 99.45% corrupt, 0% correct, 99.45% checked.
Hash check failed for file 00608.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00608.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00608.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00608.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00608.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00608.m2ts.
Hash check for /BDMV/STREAM/00608.m2ts : 99.45% corrupt, 0% correct, 99.45% checked.
Hash check failed for file 00655.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00655.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00655.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00655.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00655.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00655.m2ts.
Hash check for /BDMV/STREAM/00655.m2ts : 100% corrupt, 0% correct, 100% checked.
Hash check failed for file 00612.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00612.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00612.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00612.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00612.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00612.m2ts.
Hash check for /BDMV/STREAM/00612.m2ts : 97.73% corrupt, 0% correct, 97.73% checked.
Hash check failed for file 00626.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00626.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00626.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00626.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00626.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00626.m2ts.
Hash check for /BDMV/STREAM/00626.m2ts : 97.73% corrupt, 0% correct, 97.73% checked.
Hash check failed for file 00647.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00647.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00647.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00647.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00647.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00647.m2ts.
Hash check for /BDMV/STREAM/00647.m2ts : 98.89% corrupt, 0% correct, 98.89% checked.
Hash check failed for file 00624.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00624.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00624.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00624.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00624.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00624.m2ts.
Hash check for /BDMV/STREAM/00624.m2ts : 99.29% corrupt, 0% correct, 99.29% checked.
Hash check failed for file 00610.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00610.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00610.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00610.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00610.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00610.m2ts.
Hash check for /BDMV/STREAM/00610.m2ts : 99.29% corrupt, 0% correct, 99.29% checked.
Hash check failed for file 00615.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00615.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00615.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00615.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00615.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00615.m2ts.
Hash check for /BDMV/STREAM/00615.m2ts : 98.71% corrupt, 0% correct, 98.71% checked.
Hash check failed for file 00629.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00629.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00629.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00629.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00629.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00629.m2ts.
Hash check for /BDMV/STREAM/00629.m2ts : 98.71% corrupt, 0% correct, 98.71% checked.
Hash check failed for file 00605.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00605.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00605.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00605.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00605.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00605.m2ts.
Hash check for /BDMV/STREAM/00605.m2ts : 98.99% corrupt, 0% correct, 98.99% checked.
Hash check failed for file 00618.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00618.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00618.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00618.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00618.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00618.m2ts.
Hash check for /BDMV/STREAM/00618.m2ts : 98.99% corrupt, 0% correct, 98.99% checked.
Hash check failed for file 00102.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00102.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00102.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00102.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00102.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00102.m2ts.
Hash check for /BDMV/STREAM/00102.m2ts : 99.60% corrupt, 0% correct, 99.60% checked.
Hash check failed for file 00208.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00208.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00208.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00208.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00208.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00208.m2ts.
Hash check for /BDMV/STREAM/00208.m2ts : 98.62% corrupt, 0% correct, 98.62% checked.
Hash check failed for file 00604.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00604.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00604.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00604.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00604.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00604.m2ts.
Hash check for /BDMV/STREAM/00604.m2ts : 99.16% corrupt, 0% correct, 99.16% checked.
Hash check failed for file 00619.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00619.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00619.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00619.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00619.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00619.m2ts.
Hash check for /BDMV/STREAM/00619.m2ts : 99.16% corrupt, 0% correct, 99.16% checked.
Hash check failed for file 00116.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00116.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00116.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00116.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00116.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00116.m2ts.
Hash check for /BDMV/STREAM/00116.m2ts : 99.25% corrupt, 0% correct, 99.25% checked.
Hash check failed for file 00099.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00099.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00099.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00099.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00099.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00099.m2ts.
Hash check for /BDMV/STREAM/00099.m2ts : 99.98% corrupt, 0% correct, 99.98% checked.
Hash check failed for file 00100.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00100.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00100.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00100.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00100.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00100.m2ts.
Hash check for /BDMV/STREAM/00100.m2ts : 99.89% corrupt, 0% correct, 99.89% checked.
Hash check failed for file 00001.m2ts at offset 190464, file is corrupt.
Hash check failed for file 00001.m2ts at offset 387072, file is corrupt.
Hash check failed for file 00001.m2ts at offset 583680, file is corrupt.
Hash check failed for file 00001.m2ts at offset 780288, file is corrupt.
Hash check failed for file 00001.m2ts at offset 976896, file is corrupt.
Too many hash check errors in file 00001.m2ts.
Encountered 20173 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Backup failed
Is it because they have Dolby Vision? That seems to be the only commonality between them...
corruption
Re: titles extract without issue but disc backups corrupt
corruption wrote: Sat Dec 29, 2018 1:16 am I've read the hashcheck error help page which says it's likely a failing drive. I'm certainly open to this possibility, but I'm confused as to why I can still pull all the titles into MKVs and they play fine, while trying to backup a disc results in hashcheck errors. How can I pull the MKVs if my drive is failing? (serious question)
MakeMKV 1.14.2
The Dark Tower
Atomic Blonde
Ready Player One
Backup failed
OK, I'd read on the forums that having the drive in an external enclosure can result in these kinds of hash errors. Shucked it and threw in on a SATA2 (intel) port. Same thing. :cry:
corruption
Rolling back to v1.12.2 resolves the issue and I can successfully backup discs. @mike admin is this possibly a bug with 1.14.2?
Post by mike admin »
corruption wrote: Sun Dec 30, 2018 7:46 pm Rolling back to v1.12.2 resolves the issue and I can successfully backup discs. @mike admin is this possibly a bug with 1.14.2?
There was a bug in 1.14.1, but it was fixed in 1.14.2 . Can you please double-check the version?
corruption
mike admin wrote: Thu Jan 03, 2019 4:01 pm
Quite certain. I made sure i was on the latest version (1.14.2) as I thought perhaps I was behind. Another user is seeing similar behaviour on layer breaks:
viewtopic.php?f=12&t=18631
corruption
Mike,
I re-installed 1.14.2 and turned on debug logging. Re-ripped all 3 discs without any issue. I guess I *was* on 1.14.1?
Drivinfast247
Post by Drivinfast247 »
I'm have the same issue. Where can I find the older versions of MakeMKV?
I found them and it did not work.
