File output capped at 5580.5 MB
the2thdoc
Post by the2thdoc »
I am attempting to copy a dvd and the output file keeps getting capped at 5580.5 MB. The DVD is dual layer so the process keeps getting cut off before completion. Any ideas as to why and what can i do to fix this? Thanks
Re: File output capped at 5580.5 MB
Not without debug log information... What you describe is probably a free space issue, but MakeMKV usually won't attempt a rip if there is insufficient space on the target device.
It's not a MakeMKV limitation - I just ripped half the Studio Ghibli library, and the smallest was 25GB...
the2thdoc
Post by the2thdoc »
I don't think it is a free space issue. Destination drive has over 800 GB of free space.
I tried another disk...size is approx 6.5 GB
This time program froze at about 5.375 GB of output...see attachment
Since it freezes, I can't get log information
Any settings I should be looking at?
bmillham
Post by bmillham »
Let me guess, the drive you are writing to is formatted FAT? You need to reformat it to NTFS or exFAT (or if using linux EXT4).
A FAT filesystem limits filesize to 4GB.
Actually, MakeMKV tries to detect FAT drives, and flag them if the destination is not going to support a large file. At least, it used to; Mike may have removed that test because so many network drives reported FAT formatting, even when they weren't.
If it were a network environment, I'd suspect a per-user file allocation limit on the server for that particular user, but home networks rarely default to enforcing that limit. When something like that is in place, processes will get a "disk full" indication, even when the disk has plenty of space, if the user exceeds the limit they're allowed.
A test for that would be to remove something large from the network drive, and see if the write is allowed to proceed that much further.
