FAILURE: code 3
mkv420
FAILURE: code 3
Post by mkv420 »
On Family Guy Volume 4, Disk 1 I noticed several errors. The .mkvs appear to be fine, but is this indicative of a (potential) problem?
Opening files on harddrive at X:/DVDFAB_TMP/FullDisc/FAMILY_GUY_V4_D1/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Cell 7 was discarded (structure protection?)
Title #0 was added (6 cell(s), 0:22:33)
Title #1 was added (6 cell(s), 0:21:47)
Cell 6 was discarded (structure protection?)
Title #2 was added (5 cell(s), 0:21:34)
Title #3 was added (5 cell(s), 0:23:17)
Title #4 was added (5 cell(s), 0:21:49)
Complex multiplex encountered - 1 cells and 1148 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #5 was added (3 cell(s), 0:03:32)
Angle #2 was added for title #5
Angle #3 was added for title #5
Title #6 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
FAILURE: Code 3 at sOi[`}gfL`a5["O:213139483
Operation sucessfully completed
Saving 5 titles into directory X:/Video/FAMILY_GUY_V4_D1
5 titles saved
Re: FAILURE: code 3
Post by mike admin »
Thanks for reporting this. The error indicates that one of the streams, either audio or subtitles, was not recognized. Produced MKVs should be fine but you might have missed an extra audio or video stream. We'll keep an eye on this.
