Bad Times at the El Royale - Fails to decrypt
stuckinkodiagain
Post by stuckinkodiagain »
The "Bad Times at the El Royale" (2018) UHD blu-ray fails to decrypt in the latest version of MakeMKV (1.14.2). The dump file has been submitted to svq@makemkv.com.
Thanks, and Happy New Year, everyone!
saf001
Re: Bad Times at the El Royale - Fails to decrypt
Post by saf001 »
I'm having a similar issue with mine. Should I also submit one or is one enough?
Same issue with Night School - both 4k discs. Figured maybe it is still a bit early for the information to make it since I only received my copies today.
stuckinkodiagain
saf001 wrote: Thu Jan 03, 2019 12:17 am I'm having a similar issue with mine. Should I also submit one or is one enough?
No harm in submitting another dump, if you’d like.
And yeah, I find that new releases have trouble with MakeMKV until the decryption comes through. Turnaround is usually within the first 3-4 days before you can decrypt it, but obviously that varies based on the schedules of the developers. (Damn them for having lives of their own, y’know?)
saf001
Post by saf001 »
Hi stuckinkodiagain - did you try El Royale again? I just tried and it appears to be working ok. I also submitted my dump yesterday.
stuckinkodiagain
saf001 wrote: Thu Jan 03, 2019 10:50 pm Hi stuckinkodiagain - did you try El Royale again? I just tried and it appears to be working ok. I also submitted my dump yesterday.
Works just fine now! Thanks to the devs!
Post by SamuriHL »
Just bought this disc myself. This could be a fun one to play with since it's the first Fox title (that I'm aware of) that has HDR10+. Let the games begin! :D
FatMike
Post by FatMike »
Just finished, worked fine for me as well. Thanks all!
