my Bluray drive is not compatible with MakeMKV.
I can use my Bluray drive with DVDFab and VLC to copy or rip my Bluray, on Windows and Linux.
But I don't know why MakeMKV does not like my BR drive, please help!
My Bluray drive is not compatible with MakeMKV
legluondunet
Re: My Bluray drive is not compatible with MakeMKV
Far more helpful than the AACS dumps would be the debug logging information, which would tell us more about what MakeMKV saw, as well as what version of MakeMKV you're running.
The fact that you HAVE AACS dumps to post says that MakeMKV is talking to your drive.
legluondunet
I joined you the log file. I have no more access to my WIndows computer, so I made it from my Linux Ubuntu 18.04. The Bluray drive can be connected to USB 3.
Do you need others files? info?
legluondunet
I joined you the windows mkemkv log too.
There is nothing in the log that indicates that your drive can't be used with MakeMKV; It seems to be reading and communicating with it just fine.
The problem is with the disk. MakeMKV needs to be able to read the directory portion of the disk to create the decryption key for reading the disk, but it encounters an error. No key means that the drive will refuse to read the disk.
Have you read this topic yet? viewtopic.php?f=8&t=15055
legluondunet
I obtained the same result with MAKEMKV on all my Blu Ray discs.
Is it possible that my drive has been blocked by a Blu Ray security or protection?
My Blu Ray drive works with DVDFAB but perhaps this software uses not the same method as MAKEMKV?
"All disks" usually indicates a drive key revocation, which would be unusual for 1.14.2, because the latest "known" release of AACS, v66, is taken care of in 1.14.2. It is possible that a newer version has come out. Please check your MakeMKV data directory (pointed to by Preferences->General, Data Directory) for files that start with "MKB". The "_vXX" in the name lists the first disk MakeMKV encountered with that version of AACS.
Example, the highest version one of my machines has encountered is v63, and the file "MKB_v63_THREELEAVES_D1.tgz" means it was on a disk named "THREELEAVES_D1".
Do you have any files with names higher than "MKB_v66"?
legluondunet
This is the content of my .makemkv folder:
MKB_v17_For_A_Few_Dollars_More_4818.tgz
MKB_v25_Indiana_Jones_Bonus_Disc_4320.tgz
MKB_v27_Indiana_Jones_and_the_Kingdom_of_the_Crystal_Skull_616C.tgz
MKB_v36_JESUSCHRIST_SS_G51_7CF8.tgz
MKB_v36_Jesus_Christ_Superstar_7CF8.tgz
MKB_v4_DUNE_023C.tgz
MKB_v53_LOS_NIBELUNGOS_5DF4.tgz
MKB_v62_BLU-RAY_A502.tgz
MKB_v62_JEAN_DE_FLORETTE_A502.tgz
MKB_v9_LE_CINQUIEME_ELEMENT_95B4.tgz
_private_data.tar
screen.conf
settings.conf
update.conf
and I joined you a new log.
_private_data.tar
screen.conf
settings.conf
update.conf
Grauhaar
Hmm, what's that? Typo error?
Good Luck
legluondunet
Hello Makemkv devs, still no clue about this incompatibility? Do you need some others logs or tests?
I suggest sending a email message to support@makemkv.com with a link to this topic; that will bring it to the attention of the author, and he can ask for what he needs to answer this question. What you've posted so far says it SHOULD be working, but it obviously isn't.
legluondunet
I thought you were the aim dev/author lolWoodstock wrote: Sun Dec 30, 2018 9:38 pm I suggest sending a email message to support@makemkv.com with a link to this topic; that will bring it to the attention of the author...
Thank you for your advice, I will send him a mail.
Naw, I'm not even in the same hemisphere as Mike... I was just tagged as a moderator because I hang out here a lot, read everything, remember a lot of it, and was familiar with phpBB.
I do not see anything unusual (aside from the fact that AACS auth fails for no reason). The drive is rather old (firmware date is 2010), but it should work. Is this an USB drive?
legluondunet
It is an USB3 drive. DVDFab and AnyDVD can read my blu ray with this USB3 drive, but not MAKEMKV.
