the big bang theory (season 1, disk 1)
mkv420
#1 Post by mkv420 » Sun Apr 26, 2009 4:25 am
MakeMKV failed to extract the first episode on The Big Bang Theory, Season 1, Disk 1 (debug output below). All other episodes appear to have been packaged correctly. MakeMKV was pointed at a DVDFAB5HD extraction of the disk. It looks similar to errors found on "the usual suspects", which are planned to be fixed in the next version (1.4.2?) according to http://www.makemkv.com/forum2/viewtopic.php?t=238 - will this error be addressed at the same time?
Opening files on harddrive at X:/DVDFAB_TMP/FullDisc/THE_BIG_BANG_THEORY_SEASON1_D1/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Title #0 was added (24 cell(s), 2:07:43)
Cell 5 was discarded (structure protection?)
Title #1 was added (4 cell(s), 0:22:52)
Title #2 was added (4 cell(s), 0:21:05)
Title #3 was added (4 cell(s), 0:21:59)
Title #4 was added (4 cell(s), 0:20:38)
Title #5 was added (4 cell(s), 0:20:10)
Title #6 was added (4 cell(s), 0:20:59)
Title #7 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Operation sucessfully completed
Saving 1 titles into directory X:/Video/the_big_bang_theory_s1d1
LIBMKV_TRACE: Exception: MKV_ASSERT: (m_MarksCount==m_ChapterMarks.size()) || ((m_MarksCount+1)==m_ChapterMarks.size())
Failed to save title 0 to file X:/Video/the_big_bang_theory_s1d1/title00.mkv
0 titles saved, 1 failed
Re: the big bang theory (season 1, disk 1)
#2 Post by mike admin » Mon Apr 27, 2009 11:07 am
Yes. This error will be addressed in 1.4.2 which will be available in few days. The next release will also correct "all subtitles are the same language" problem, produce more compatible chapters and bring DVD LPCM support.
mkv420
#3 Post by mkv420 » Wed May 06, 2009 5:57 am
I can confirm that 1.4.2 did correct this issue with "the big bang theory, season 1, disk 1" however "the usual suspects" still has issues (details in the usual suspects thread).
