A Simple Favor (DVD)
Kappabear
#1 Post by Kappabear » Wed Dec 19, 2018 2:21 am
I'm attempting to extract the correct Title from the "A Simple Favor" DVD. When I play it using Apple's DVD Player, it shows that Title 71 is what I want. When I open the disc in MakeMKV, I see "Title #71 was added (17 cell(s), 1:56:37)", but when I look at the lists of titles, none of the titles contain Source ID: 71.
The Duration is: 1:56:51 according to the Apple DVD Player, and none of the tracks have this exact length.
This is the closest in duration:
Title information
Source title ID: 62
Duration: 1:56:37
Chapters count: 16
Segment count: 1
Segment map: 2-18
File name: title_t19.mkv
Everything else is longer or shorter by a few minutes.
How do I determine which DVD title to save/extract?
MakeMKV v1.14.2 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/jeffp/MakeMKV_log.txt
Optical drive "DVD+R-DL TSSTcorp CDDVDW SH-S202N SB02d" opened in OS access mode.
Title #1/0/4 has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1/0/6 was added (1 cell(s), 0:06:33)
Title #2 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 was added (1 cell(s), 0:19:39)
Title #5 was added (1 cell(s), 0:06:10)
Title #6 was added (1 cell(s), 0:04:46)
Title #7 was added (1 cell(s), 0:05:22)
Title #8 was added (1 cell(s), 0:04:54)
Title #9 was added (1 cell(s), 0:04:33)
Title #11 was added (1 cell(s), 0:03:30)
Title #17 was added (10 cell(s), 0:11:31)
Title #18 was added (11 cell(s), 0:11:43)
Title #29 was added (1 cell(s), 0:04:52)
Title #30 was added (2 cell(s), 0:05:56)
Title #34 has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 was added (1 cell(s), 0:02:26)
Title #37 was added (1 cell(s), 0:02:26)
Title #38 has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 has length of 105 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 was added (1 cell(s), 0:02:34)
Title #41 was added (1 cell(s), 0:02:34)
Title #46 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #47 has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #48 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #49 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #52 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #53 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54 was added (1 cell(s), 0:24:45)
Title #55 was added (1 cell(s), 0:25:15)
Title #58 was added (19 cell(s), 1:58:34)
Cells 2-4 were skipped due to cell commands (structure protection?)
Title #60 was added (17 cell(s), 1:54:13)
Title #61 was added (17 cell(s), 1:54:03)
DEBUG: Code 10551303 at EnT#jQ5phhj{*{Ay:213142496
DEBUG: Code 0 at EnT#jQ5phhj{*{Ay:121274998
DEBUG: Code 0 at a*kJ^xCf~iS<O</zpa:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 19-19 were removed from title end
Title #62 was added (17 cell(s), 1:56:37)
Title #63 was added (17 cell(s), 1:54:37)
Title #64 was added (17 cell(s), 1:56:37)
Title #65 was added (17 cell(s), 1:54:06)
Title #66 was added (19 cell(s), 1:58:34)
Title #67 was added (17 cell(s), 1:56:37)
Title #68 was added (19 cell(s), 1:58:34)
Title #69 was added (19 cell(s), 1:58:34)
Title #70 was added (17 cell(s), 1:56:37)
Title 2 in VTS 7 is equal to title 1 and was skipped
Title 2 in VTS 9 is equal to title 1 and was skipped
Title 1 in VTS 22 is equal to title 1 and was skipped
Title 1 in VTS 26 is equal to title 1 and was skipped
markclane@gmail.com
Re: A Simple Favor (DVD)
#2 Post by markclane@gmail.com » Thu Dec 27, 2018 2:48 am
You might want to try title 60.
Kappabear
#3 Post by Kappabear » Thu Dec 27, 2018 4:27 pm
Why title 60? What do you see that makes you feel that’s “the one?”
Arry1587
#4 Post by Arry1587 » Sat Dec 29, 2018 6:57 pm
When it comes to Lionsgate DVDs, I just copy all the main movie titles with the options I want. Some titles fail ('medium error'/'uncorrectable error') at the end and weren't the correct ones anyway, the rest show egregious a/v errors such as missing audio/gap or a/v is out of sync by as much as around 500ms, etc, and the correct one is the one that had 0 errors/notices in the log.
I also have "Show AV synchronization messages" enabled.
IIRC, it was 'title_19.mkv' for 'A Simple Favor' that saved without any notices in the log. Never went wrong with this methodology, so far, but it takes longer..
