Creed
Big-rome
Creed
Post by Big-rome » Thu Dec 27, 2018 12:59 am
Creed just hangs in the middle of ripping.
https://pastebin.com/2hyGyfB7
Re: Creed
Post by Woodstock » Thu Dec 27, 2018 2:25 am
Does Linux log anything regarding the hang?
The debug code at the end of the log also occurs earlier at the same location. Mike's the one with the magic debug decoder ring, so this is one that he'll have to answer.
Big-rome
Re: Creed
Post by Big-rome » Thu Dec 27, 2018 8:35 am
I would have to run it again to check the linux log.
Big-rome
Re: Creed
Post by Big-rome » Thu Dec 27, 2018 8:38 am
I get that same debug code with life of pi which also fails to rip, rip speed slows to zero and I get failed to copy.
Big-rome
Re: Creed
Post by Big-rome » Thu Dec 27, 2018 8:57 am
usb 4-6: reset SuperSpeed USB device number 3 using xhci_hcd
[ 1316.882997] sr 7:0:0:0: [sr0] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[ 1316.883000] sr 7:0:0:0: [sr0] tag#0 Sense Key : Medium Error [current]
[ 1316.883002] sr 7:0:0:0: [sr0] tag#0 Add. Sense: L-EC uncorrectable error
[ 1316.883004] sr 7:0:0:0: [sr0] tag#0 CDB: Read(10) 28 00 00 f8 bd 60 00 00 c0 00
[ 1316.883005] print_req_error: critical medium error, dev sr0, sector 65205632
[ 1374.999476] usb 4-6: reset SuperSpeed USB device number 3 using xhci_hcd
[ 1411.851559] usb 4-6: reset SuperSpeed USB device number 3 using xhci_hcd
Re: Creed
Post by Woodstock » Thu Dec 27, 2018 2:06 pm
OK, it looks like Linux is not passing through the read error to MakeMKV.
By the log, this is a USB drive, powered by the USB port. Is it plugged into a fully-powered USB 3.x port, or a hub? USB-powered drives can shut down if you spin them too fast for the available USB power. A fully-powered USB 3.x should not have this issue, but a non-powered hub can be a problem.
Do you have available a USB flash drive big enough to hold the movie, and formatted in NTFS? If so, can you set that as the destination drive, and try the rip again? Flash drives can't accept full read speed (usually), which throttles MakeMKV, and MAY make this problem "go away". If it does, getting full power to the drive will be the permanent fix.
Big-rome
Re: Creed
Post by Big-rome » Thu Dec 27, 2018 5:51 pm
Yes fully powered and its a samsung 840EVO ssd. Out of 25 disc only 3 gave me trouble. Creed, Conan and life of pi. Conan ripped once I added keyhash.txt.
Re: Creed
Post by Woodstock » Thu Dec 27, 2018 8:40 pm
I was referring to slowing the write - the Samsung SSD will accept data faster than even MakeMKV can pull from an optical disk, so it won't serve as a "throttle".
Using a USB flash drive limits the writing speed, so MakeMKV can't spin the optical disk as fast. A USB 2.x flash drive is optimal for testing, because it will limit read speeds to the 5-6x range. If that makes the rip succeed, then the optical drive is not able to run at full speed with the power available.
Big-rome
Re: Creed
Post by Big-rome » Thu Dec 27, 2018 11:47 pm
The biggest usb device I have 32gb and its usb3.
Re: Creed
Post by Woodstock » Fri Dec 28, 2018 5:43 am
Drat.... I have so many 64- and 128-GB flash drives I use for transfers I forget that not everyone does that.
Big-rome
Re: Creed
Post by Big-rome » Fri Feb 08, 2019 5:58 pm
Tried again with libreDrive and got a successful rip.
