DVDs not ripping
Sheldor
DVDs not ripping
Post by Sheldor » Sun Dec 23, 2018 1:08 am
Hello all,
I am having an issue today where my DVDs are not ripping. I was able to rip 1 movie in the normal 15 min then when I tried the second one it sees its there, I can select the chapter/movie I want to rip then after that nothing. I have tried it on 2 different DVD drives and 2 different computers. I have upgraded to the most recent version and still no luck. I have attached a screen shot of what its showing.
Re: DVDs not ripping
Post by Woodstock » Sun Dec 23, 2018 1:57 am
Do you have debug logging enabled? (FAQ link in my signature)
Are you getting any error messages?
Sheldor
Post by Sheldor » Sun Dec 23, 2018 3:31 pm
I am getting this but it goes on for a long time. I left it running over night and the movie finally finished after 5 hours.
Debug log started at Sun Dec 23 03:07:28 2018 , written by MakeMKV v1.14.2 win(x64-release)
001005:0000 MakeMKV v1.14.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Max/MakeMKV_log.txt
DEBUG: Code 2365587456 at 3tu+2QPU[=7Te!Z9e:29394620
DEBUG: Code 0 at FH7EnU8#[L=V`R*^j:121261819
DEBUG: Code 0 at FH7EnU8#[L=V`R*^j:29393815
003028:0000 Title #1 was added (31 cell(s), 1:56:10)
003025:0000 Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #4 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #5 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 7-end were skipped due to cell commands (structure protection?)
003028:0000 Title #6 was added (6 cell(s), 0:08:34)
003019:0000 Cells 8-end were skipped due to cell commands (structure protection?)
Title skip vts=2 pgcn=1 hash=E721900D8049B551
003028:0000 Title #7 was added (1 cell(s), 0:06:40)
003030:0000 Subtitle stream #3 is identical to stream #2 and was skipped
003030:0000 Subtitle stream #4 is identical to stream #2 and was skipped
003030:0000 Subtitle stream #5 is identical to stream #2 and was skipped
003030:0000 Subtitle stream #6 is identical to stream #2 and was skipped
001003:0020 DEBUG: Code 233 at FwvELW+qS+8O1uv98XvrdHih:0
005014:0000 Saving 1 titles into directory C:/Users/Max/Downloads/Max Tinkey/Plex/New Ripped Movies 2
AV sync issues in C:/Users/Max/Downloads/Max Tinkey/Plex/New Ripped Movies 2/300_t00.mkv
AV sync in 1 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18.033ms
AV sync in 2 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18.033ms
AV sync in 3 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18.011ms
AV sync in 4 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18.033ms
AV sync in 5 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +18ms
DEBUG: Code 256 at D`n#H4_P5x]ysv&d[.a:213132652
CCX001: Launching C:\Program Files (x86)\MakeMKV\mmccextr64.exe
CCX001: CCExtractor 0.85, Carlos Fernandez Sanz, Volker Quetschke.
CCX001: Teletext portions taken from Petr Kutalek's telxcc
CCX001: This is a reduced-functionality version optimised for DVD closed captions transcoding.
CCX001: --------------------------------------------------------------------------
CCX001: Reading from standard input
CCX001: Analyzing data in CCExtractor's binary format
CCX001: Sending captions to stdout.
DEBUG: Code 512 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 768 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1024 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1280 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1536 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 1792 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2048 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2304 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2560 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 2816 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3072 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3328 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3584 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 3840 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4096 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4352 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4608 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 4864 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5120 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5376 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5632 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 5888 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6144 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6400 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6656 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 6912 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7168 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7424 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7680 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 7936 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8192 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8448 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8704 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 8960 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9216 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9472 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9728 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 9984 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 10240 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 10496 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 10752 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 11008 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 11264 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 11520 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 11776 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 12032 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 12288 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 12544 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 12800 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 13056 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 13312 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 13568 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 13824 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 14080 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 14336 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 14592 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 14848 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 15104 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 15360 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 15616 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 15872 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 16128 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 16384 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 16640 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 16896 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 17152 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 17408 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 17664 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 17920 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 18176 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 18432 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 18688 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 18944 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 19200 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 19456 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 19712 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 19968 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 20224 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 20480 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 20736 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 20992 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 21248 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 21504 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 21760 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 22016 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 22272 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 22528 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 22784 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 23040 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 23296 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 23552 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 23808 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 24064 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 24320 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 24576 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 24832 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 25088 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 25344 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 25600 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 25856 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 26112 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 26368 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 26624 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 26880 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 27136 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 27392 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 27648 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 27904 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 28160 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 28416 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 28672 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 28928 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 29184 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 29440 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 29696 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 29952 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 30208 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 30464 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 30720 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 30976 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 31232 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 31488 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 31744 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 32000 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 32256 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 32512 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 32768 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 33024 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 33280 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 33536 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 33792 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 34048 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 34304 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 34560 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 34816 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 35072 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 35328 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 35584 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 35840 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 36096 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 36352 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 36608 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 36864 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 37120 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 37376 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 37632 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 37888 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 38144 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 38400 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 38656 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 38912 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 39168 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 39424 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 39680 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 39936 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 40192 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 40448 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 40704 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 40960 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 41216 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 41472 at D`n#H4_P5x]ysv&d[.a:213132652
DEBUG: Code 41728 at D`n#H4_P5x]ysv&d[.a:2131326
Post by Woodstock » Mon Dec 24, 2018 12:37 am
Does it make a difference in ripping time if you do NOT select the closed caption track?
Sheldor
Post by Sheldor » Mon Dec 24, 2018 3:54 am
No. The movie ended up ripping. I let it sit over night it took 5 hours now every movie i put in its only taking 15-25min. It must have just been that movie. "300". I have never had this issue before.
nocomments87
Post by nocomments87 » Thu Jan 03, 2019 1:07 am
I've had the same issue on a few discs. For the hell of it, I decided I'd try out an older version to see if it produced the same result. Turns out, it didn't...it actually ripped flawlessly with an older version vs. the current one. I used 1.12.3 and had more success ripping DVDs (and even some Blu-rays) with that than I did 1.14.2. I guess newer isn't always better.
tkrusterholz
Post by tkrusterholz » Thu Jan 03, 2019 5:58 pm
I am also having this issue today. Have been ripping various DVDs and BluRays since last night, today I am stuck on Casablanca. I will just let this run all day and see if it finishes eventually in several hours. Otherwise I may try downgrading to 1.12.3 as nocomments87 suggested.
truckmann
Post by truckmann » Mon Jan 28, 2019 10:30 pm
I was having similar issues today as well. Version 1.14.2 would not open any DVDs I tried. I emailed a log file on that. I downgraded to 1.14.1 and it would open the discs and some would rip okay and some it was telling me it was going to take several hours to finish. First time I ran into the issue I used the old DVD Decrypter to rip and it ripped in a normal 30ish minute time. Next one I did with MakeMKV and it was fine then the one after that was slow again. I downgraded to 1.12.3 for that one and it is back to normal pace. The 1.14.x versions seem to be having trouble with DVDs compared to the 1.12.x versions for some reason. All issues on Harry Potter movies today. I also Tried Batman begins as a test when the latest version wouldn't read anything.
smr888
Post by smr888 » Wed Feb 27, 2019 2:44 pm
I have had the same problem consistently. Maybe three of the last 12 or so DVDs I tried to rip would rip properly, and the usual symptom was the spinning with no progress being made. I'm wondering if this is due to something changing in Windows, because I haven't had this problem in the past. I did try uninstall/reinstall with no improvement. How do you downgrade to 1.12.3? I can't find an install for that.
BlueMac77
Post by BlueMac77 » Wed Feb 27, 2019 4:37 pm
smr888 wrote: Wed Feb 27, 2019 2:44 pm I have had the same problem consistently. Maybe three of the last 12 or so DVDs I tried to rip would rip properly, and the usual symptom was the spinning with no progress being made. I'm wondering if this is due to something changing in Windows, because I haven't had this problem in the past. I did try uninstall/reinstall with no improvement. How do you downgrade to 1.12.3? I can't find an install for that.
You can download the old versions here https://makemkv.com/download/old/
Is your optical drive connected internally or are you using a slim USB powered drive?
smr888
Post by smr888 » Wed Feb 27, 2019 7:40 pm
Thanks for that link. I'll try it.
My optical drives are internal. Today I've tried two different computers, two different DVDs, same result. In the recent past I've tried several other DVDs and had maybe 20% work. This is a definite change from prior to . . . something . . . because I've never had this many disks fail to rip.
