Bad Boys I & II UHD Backups Failed
Chipless
I've cleaned the discs multiple times with a lens cleaning cloth plus an alcohol/water solution, but I am still getting backup failed within the first 15 seconds of attempting to backup either disc. No error message, but both discs seem to fail at "ContentHash000.tbl" file each time. Any suggestions?
st4evr
Re: Bad Boys I & II UHD Backups Failed
Do you have logs on? If not read:Chipless wrote: Wed Dec 12, 2018 1:20 am No error message, but both doscs seem to fail at "ContentHash000.tbl" file each time. Any suggestions?
https://www.makemkv.com/faq/item/8
Then provide the log if it creates one. With that information it may be easier for forums members to advise.
Chipless
Thank you for the suggestion! Simply enabling the logs somehow fixed the issue. I successfully backed up Bad Boys II and Bad Boys I is currently past the failure point, so I am guessing it will complete as well.
