make mkv log file after ripping a disc?
smartieyoung
Post by smartieyoung » Fri Dec 14, 2018 11:47 pm
I'm just curious about where make mkv stores log files,also curious about how many log files per title are made?
Re: make mkv log file after ripping a disc?
Post by Woodstock » Sat Dec 15, 2018 12:59 am
If you have debug logging turned on, when you start MakeMKV it will tell you exactly where the log file is stored.
There is one log file per session, however many disks you rip during that session.
If you run multiple copies of MakeMKV, each will have its own session log.
smartieyoung
Post by smartieyoung » Sun Dec 16, 2018 3:13 am
Thank you woodstock for the clarification.that helps me out quite a bit. :D
wrxmarcus
Post by wrxmarcus » Mon Mar 11, 2019 5:45 pm
Does the old log data get blown away when you start a new session? My log file only seems to have my last successful rip.
Thank you
Post by Woodstock » Mon Mar 11, 2019 7:37 pm
Yes, the debug logs are overwritten each time you start MakeMKV.
