Arrival UHD UK
VeryWittyName
Arrival UHD UK
I bought Arrival 4K a few weeks ago when it came out in the UK and I've emailed the dump file a couple of times to get the key added but it still seems to be missing from the registry. Anyone have any ideas on how to proceed from here?
Re: Arrival UHD UK
What version of the app are you on?
What is the exact error/warning being returned by MakeMKV as shown in the log/app?
This information could help forums members in advising you with next steps.
VeryWittyName
Re: Arrival UHD UK
Apologies. MakeMKV is version 1.14.2, Windows x64. Trying to open the disc or the saved backup results in "The volume key is unknown for this disc - video can't be decrypted - Failed to open disc". The 4K version of The Lion King works and that came out after I sent the dump file in (C:\Users\[me]/.MakeMKV/MKB20_v61_Arrival_04D5.tgz). Just wondering if I'm doing something completely wrong!
Re: Arrival UHD UK
Sounds like you are receiving new keys. So....
First, make sure you are sending your dumps to:
svq@makemkv.com
If you got that covered, try reaching Mike at:
support@makemkv.com
Include your error/log, reason/explanation for the email and what’s going on (as detailed as possible), and attach your dump again. Maybe it was missed or skipped for some reason. He may reach back out to you with an explanation/answer/solution.
svq@makemkv.com
support@makemkv.com
VeryWittyName
Re: Arrival UHD UK
Thanks, I've sent another email but to both email addresses this time. Hopefully it gets picked up soon.
