Incredibles 2
Re: Incredibles 2
You can download old versions (if you didn't keep a copy of them) from https://makemkv.com/download/old/
And you can have multiple versions installed, so long as they are in different program directories.
audioguy
Re: Incredibles 2
Post by audioguy »
I tried again using a different drive and it worked fine?????
eng050599
Re: Incredibles 2
Post by eng050599 »
audioguy wrote:
Mon Dec 03, 2018 5:35 pm
Unfortunately, there does appear to be an issue with some drives being able to read the discs. In the case of Blade Runner, and Batman Begins, I couldn't get successful rips. In both cases, I got Amazon to arrange a replacement, calling the disc unreadable.
The new discs ripped without issue. Trying it on another drive, may also be a valid option.
In this instance, I had no issues ripping Incredibles 2...once I figured out which of the 3 titles MakeMKV listed was the correct one.
EROracing
Re: Incredibles 2
Post by EROracing »
I'm having trouble right now ripping incredibles 2. It starts just fine but fails after like 10min. Any suggestions?
pcolmer
Re: Incredibles 2
Post by pcolmer »
eng050599 wrote:
Sun Dec 09, 2018 7:32 am
How did you figure this out? Each title is showing a slightly different segment map but I have no idea what the actual difference would be between the three versions.
Thanks.
Philip
Re: Incredibles 2
Disney (who owns Pixar) uses a standard format. The play list that ends in 800.mpls is Engish. 801 and 802 have different languages for the titles and credits, usually Spanish and French, respectively.
StealMySoda
Re: Incredibles 2
Post by StealMySoda »
It took me around 5 attempts to get this to rip. In the end I used the 800 playlist, but had to rip without the HD soundtrack.
