Hell or High Water UHD
sharpie00
#1 Post by sharpie00 » Sun Dec 02, 2018 10:23 pm
Hello members,
Curious if anyone else has trouble with the Hell or High Water UHD disc? I've tried both my LG and ASUS drives and both of them error out when trying to read the disc. It causes MakeMKV to crash. I have 70+ 4K discs and this is the first time I've run into an issue with a disc. I've checked and the disc looks good. Brand new purchased over Black Friday so I couldn't resist a good deal.
On a separate note, I'm having a similar issue with Independence Day UHD (the original movie, not the sequel).
Just wanted to know if it's me or these are 2 movies I'll just have to play from the disc.
st4evr
Re: Hell or High Water UHD
#2 Post by st4evr » Mon Dec 03, 2018 4:47 am
I can confirm at least one variation of those discs have been succesfully backed up.
Help us help you by posting any logs/errors you are receiving if any. With that information maybe someone can advised.
sharpie00
#3 Post by sharpie00 » Mon Dec 03, 2018 11:11 pm
Thanks st4evr.
Here is the log from Independence Day UHD.
DEBUG: Code 03DF
Title #00170.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.mpls has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
File 00801.mpls was added as title #1
File 00802.mpls was added as title #2
File 00803.mpls was added as title #3
Title #00070.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00076.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00100.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00101.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00077.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00078.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00149.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00083.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00085.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00089.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00090.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00192.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00075.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00600.m2ts was added as title #4
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00191.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00170.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00171.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00172.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00173.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00601.m2ts has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00602.m2ts was added as title #5
Title #00603.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00604.m2ts was added as title #6
Title #00605.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00606.m2ts was added as title #7
Title #00607.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00608.m2ts was added as title #8
Title #00609.m2ts has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00610.m2ts was added as title #9
Title #00611.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00612.m2ts was added as title #10
Title #00613.m2ts has length of 43 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00614.m2ts was added as title #11
Title #00615.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00616.m2ts was added as title #12
Title #00617.m2ts has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00618.m2ts was added as title #13
Title #00619.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00620.m2ts was added as title #14
Title #00621.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00622.m2ts was added as title #15
Title #00623.m2ts has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00624.m2ts has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00625.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00626.m2ts was added as title #16
Title #00627.m2ts has length of 55 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00628.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00629.m2ts has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00630.m2ts has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00631.m2ts was added as title #17
Title #00632.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00633.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00174.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00175.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/*****/Movies
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00604.m2ts' at offset '6203572224'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '6203572224'
Failed to save title 1 to file /Users/*****/Movies/Independence Day_t01.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
sharpie00
#4 Post by sharpie00 » Mon Dec 03, 2018 11:23 pm
And here's the log for Hell or High Water UHD. This one just gets stuck. Doesn't do anything after trying to Analyze Seamless Segments.
Thanks for the insight :)
MakeMKV v1.14.2 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BE16NU50 1.01d" opened in OS access mode.
DEBUG: Code 03DF
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Title #00011.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00801.mpls was added as title #0
File 00451.mpls was added as title #1
File 00452.mpls was added as title #2
File 00453.mpls was added as title #3
Title #00454.mpls has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00455.mpls was added as title #4
Title #00012.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00800.mpls is equal to title 00801.mpls and was skipped
Title #00013.mpls has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00276.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00277.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00278.m2ts was added as title #5
Title #00282.m2ts has length of 114 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00284.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00285.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00286.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
The source file '/BDMV/STREAM/00278.m2ts' is corrupt or invalid at offset 61440, attempting to work around
Hash check failed for file 00278.m2ts at offset 190464, file is corrupt.
Saber008
#5 Post by Saber008 » Fri Dec 07, 2018 12:12 am
I've recently done Hell or High Water and Independence Day and no issues to report. Perhaps your luck is catching up with you since it is quite common to get defective UHD discs and you have had 70+ without error. I just had one with The Bridge on the River Kwai and Dunkirk when it was released. If cleaning the disc doesn't help then I would exchange for another.
notta
#6 Post by notta » Fri Dec 07, 2018 1:32 am
I just picked up Independence Day the other day from Best Buy and I am getting the same thing "Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR'". It's good to know it's not just me.
sharpie00
#7 Post by sharpie00 » Fri Dec 07, 2018 9:37 pm
Saber008 wrote: Fri Dec 07, 2018 12:12 am I've recently done Hell or High Water and Independence Day and no issues to report. Perhaps your luck is catching up with you since it is quite common to get defective UHD discs and you have had 70+ without error. I just had one with The Bridge on the River Kwai and Dunkirk when it was released. If cleaning the disc doesn't help then I would exchange for another.
Thanks bud. I may just do that this weekend.
sharpie00
#8 Post by sharpie00 » Fri Dec 07, 2018 9:39 pm
notta wrote: Fri Dec 07, 2018 1:32 am I just picked up Independence Day the other day from Best Buy and I am getting the same thing "Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR'". It's good to know it's not just me.
I'll keep you posted to see if anything changes once I exchange the discs. Stay tuned :)
notta
#9 Post by notta » Sat Dec 08, 2018 2:23 am
sharpie00 wrote: Fri Dec 07, 2018 9:39 pm
Thanks. I'm eager to see if it happens again. My drive sounded like it was going to blow up it reading the disc. Do you think Best Buy would exchange the disc? I didn't think they would since it's been opened. If I say the disc is bad they are going to look at it and say the disc looks perfect. Don't know.
sharpie00
#10 Post by sharpie00 » Sat Dec 08, 2018 9:59 pm
Confirmed.
2 bad discs. Got replacement ones and both worked.
Just an fyi. Thanks :)
notta
#11 Post by notta » Sat Dec 08, 2018 11:19 pm
sharpie00 wrote: Sat Dec 08, 2018 9:59 pm Confirmed.
Just and fyi. Thanks :)
That's good to hear. I posted something the other day but I assume it was denied because other posts have appeared. Does everyone have to get their posts approved or is there a post count you have to meet or something? Anyway, I bought this from Best Buy. Will they swap it out with another one even though I opened it already?
Thanks.
corzamoon
#12 Post by corzamoon » Sat Feb 16, 2019 8:19 am
Hi, I'm also having issues with Independence Day. I'm trying to rip the Australian release, but judging by the disc itself, it might be the same release as the one in the US coz of the disc print, and also coz the US release was region free.
I've tried 2 different discs now. I got it replaced, but same issue.
'/BDMV/STREAM/00610.m2ts' is corrupt or invalid at offset 4802758656.
It cannot get past this m2ts file. Even though a year between replacement, I guess they're from the same batch maybe.
I also have same issues with:
- Fantastic Beasts and Where to Find them
- X-Men First Class
- Harry Potter Deathly Hallows Pt 1
Currently have the LG drive, but might try to install the Asus firmware on it. Will that help?
#13 Post by MartyMcNuts » Sat Feb 16, 2019 8:35 am
@corzamoon,
FYI, all UHD’s are region free.
Also, I’m pretty sure that Independence Day was one of the discs that I had an issue with. I alway try with my LG 1.02 first and if that doesn’t work, I use my LG (asus 3.02) which has worked.
I’ve never had to return a disc yet!
I’d suggest trying the asus firmware. Don’t forget to use the new method to flash your drive!
corzamoon
#14 Post by corzamoon » Mon Feb 18, 2019 7:39 pm
MartyMcNuts wrote: Sat Feb 16, 2019 8:35 am @corzamoon,
That made a huge difference. The Asus firmware managed to rip nearly all the problematic discs. Only X-Men: First Class and Crouching Tiger, Hidden Dragon remain, but I read on the forum that they may be addressed in the next update of MakeMKV.
I didn’t know all UHD were region free. I’ve noticed a few say “region free” on blu-ray.com but a lot also say untested in other regions so I didn’t know for sure. Thanks for the info!
