A Simple Favor (US Retail)
Cornstick
Post by Cornstick »
Not positive about this. US Retail
Name: A Simple Favor (English)
Source file name: 00308.mpls
Duration: 1:56:50
Chapters count: 16
Segment count: 15
Segment map: 514,511,509,510,504,513,501,506,507,515,505,502,508,512,503
File name: A Simple Favor_t83.mkv
johng
Re: A Simple Favor (US Retail)
Post by johng »
Did this ever get verified? Any idea if the Netflix version is the same?
dbtayag
Post by dbtayag »
Remember guys, this is a Lionsgate release.
Grisle
Post by Grisle »
RD Version
Title information
Source file name: 00519.mpls
Duration: 1:56:50
Chapters count: 16
Segment count: 15
Segment map: 505,513,511,508,503,504,506,509,501,507,510,502,515,514,512
File name: A Simple Favor_t138.mkv
Used AnyDVD, but have not watched to verify.
dp5081
Post by dp5081 »
RB version doesn't contain 308. just a heads up.
Grisle
Post by Grisle »
Sorry, supposed to be RB version in my post not RD
Kappabear
Post by Kappabear »
Folks, I'm not quite a newbie, but certainly no expert either. I'm attempting to extract the correct Title from this DVD. When I play it using Apple's DVD Player, it shows that Title 71 is what I want. When I open the disc in MakeMKV, I see "Title #71 was added (17 cell(s), 1:56:37)", but when I look at the lists of titles, none of the titles contain Source ID: 71.
How do I determine which DVD title to save/extract? (I've heard that Lionsgate discs are much harder to determine.)
Would someone please explain to me what is discussed/talked about in the threads above, and how you determined the information? Also, I'm not seeing "Source file name", or "Size", "Segment count", "segment map" or "File name" that matches what is being shown. Perhaps I'm looking at the DVD, and the above is from the BluRay?
Grisle
Post by Grisle »
My info is for the RB Bluray version.
I had AnyDVD scan the disk and gave me a good playlist of 519, but as I said I have not watched it to verify this is correct at this point.
Lovely Rita
Post by Lovely Rita »
Kappabear wrote: Tue Dec 18, 2018 10:32 pm Folks, I'm not quite a newbie, but certainly no expert either. I'm attempting to extract the correct Title from this DVD. When I play it using Apple's DVD Player, it shows that Title 71 is what I want. When I open the disc in MakeMKV, I see "Title #71 was added (17 cell(s), 1:56:37)", but when I look at the lists of titles, none of the titles contain Source ID: 71.
Yes, this is the BluRay section. :)
Your questions should be posted under DVD topics.
Lionsgate discs ARE a PIA (much more than the Disney disc you and talked about recently) but I suggest we continue this conversation in the proper topic section. I would suggest posting there.
Registered User :wink:
Buy MakeMKV
tornadobox
Post by tornadobox »
Does it matter that my file name is different? Everything else checks out the same. This is for the RB version (I'm assuming RB stands for the brightly colored machine source).
Title information
Duration: 1:56:50
Chapters count: 16
Segment count: 15
File name: A Simple Favor_t140.mkv
TheBreeze
Post by TheBreeze »
My MakeMKV chose 399.mpls, title 3 on my RB disc as the main feature. I already burned 519.mpls as suggested by Grisle. We'll see.
isuzudave
Post by isuzudave »
tornadobox wrote: Wed Dec 19, 2018 12:13 am Does it matter that my file name is different? Everything else checks out the same. This is for the RB version (I'm assuming RB stands for the brightly colored machine source).
Title information
Duration: 1:56:50
Chapters count: 16
Segment count: 15
I don't think it matters that the file name is different. It's the source file name you are need to look at. They might have MakeMKV configured so it skips certain files on the disc and this would result in file number differences.
fozbot
Post by fozbot »
Grisle wrote: Tue Dec 18, 2018 3:46 pm RD Version
Title information
Duration: 1:56:50
Chapters count: 16
Segment count: 15
Confirmed Grisle post - I used the 519.mpls on RB version and watched it last night. Thanks
Crtguy
Post by Crtguy »
519.mpls is correct for Netflix also.
nickelmouse
Post by nickelmouse »
Cornstick wrote: Thu Dec 06, 2018 5:20 am Not positive about this. US Retail
Duration: 1:56:50
Chapters count: 16
Segment count: 15
I also got 00308.mpls for US Retail 4K/Blu-ray using Process Monitor. Interesting that 4K movies are now simpler to rip than their Blu-ray counterparts (at least, from the user perspective dealing with obfuscation...not the actual decryption from Mike).
