Heads up - Support for LG UHD drives
pirata1987
Re: Heads up - Support for LG UHD drives
Post by pirata1987 »
Hi ... I'm using a official UHD driver WH16NS60
v1.00 , someone can tell me if is possible yo flash with a friendly firmware and if will work ? Thanks
st4evr
Post by st4evr »
pirata1987 wrote:
Tue Dec 04, 2018 2:04 pm
Yes you can. Discussed many times already and you have already been told twice by two different members here that yes it’s possible to crossflash that drive to make it work. The answer is not going to change. Let’s hope this third time is the charm and it sticks. READ:
Option 1:
https://www.makemkv.com/forum/viewtopic ... 16&t=17091
Option 2:
https://forum.cdrinfo.pl/f29/crossflash ... s58-96313/
Option 3:
https://www.makemkv.com/forum/viewtopic ... 16&t=18411
Additional discussions on the matter:
https://www.makemkv.com/forum/search.ph ... s=WH16NS60
For that second link you will need to translate the page to your desired language using something like Google translate.
babypuncher
Post by babypuncher »
mike admin wrote:
Sun Dec 02, 2018 4:07 pm
babypuncher wrote:
Tue Nov 27, 2018 2:58 am
Will this include support for re-badged BU50Ns like the Buffalo BRUHD-PU3?
Yes, but confirmation is needed. Do you have the drive by any chance?
I do in fact have this drive!
Jorn-G
Post by Jorn-G »
i have a BU40n from LG which is almost the same spec as BU50n.
Will it be supported as well or not?
Thanks,
Jörn
lockdown571
Post by lockdown571 »
babypuncher wrote:
Thu Dec 06, 2018 2:08 am
I do as well and would be happy to test.
Post by mike admin »
spl147 wrote:
Mon Dec 03, 2018 10:00 pm
Will there be an advantage to using a official drive vs a friendly drive?
Yes, the absence of "sleep" bug and (presumably) the better support of UHD-rom discs. Ability to make a warranty repair if drive stops reading UHD-ROM discs...
Will an official drive be a requirement at some point?
No. All current "friendly" (and "supported "official") drives will work forever, in a sense that no official firmware or AACS update would make them unusable.
Malkana
Post by Malkana »
Do we have an ETA? Will it be before Christmas?
jonghotti
Post by jonghotti »
Check with your uhd friendly drive supplier about the warranty issue. I will take care of any warranty issues that arise if you purchased your drive from me.
Jorn-G
Post by Jorn-G »
Nobody an idea regarding this
https://www.lg.com/us/burners-drives/lg-BU40N
Drive?
Actually when i search for LG BU50N i don´t even find a similar page at LG... anyhow - quite some images on Google Picture search.
Could this be the european Version which is not visible on LG Side from my IP?
Jorn-G wrote:
Thu Dec 06, 2018 9:04 am
Thanks,
Jörn
mgrobins
Post by mgrobins »
Just to make this crystal clear in my mind having read the evolving 32= PGE Thread about friendly and UHD drives and the fw hassles....
LG are now supportive of f/w on the WH16NS60 and Makemkv will read discs in it and rip them the way we currently rip Blu-ray discs..... choosing the movie, audio streams and subs etc.
Is this correct?
I am trying to work out why this drive is so scarce in Australia.
jonghotti
Post by jonghotti »
mgrobins wrote:
Tue Dec 11, 2018 4:47 pm
Is this correct?
LG, the company, is not supportive of anything, especially the idea of kicking down a BU30N when asked nicely :-)
Nothing has changed as of yet with the WH16NS60. They can be flashed and made usable with makeMKV but are not yet natively supported.
st4evr
Post by st4evr »
To add to jonghotti's correct answer. LG has nothing to do with and will never have anything to do with anything developers like Mike are doing here. Start by getting that idea out of your mind.
And in theory, yes, technically when Mike adds support to his application for this drive with stock firmware we should be able to do as you mention.
jonghotti
Post by jonghotti »
Edited.
Huge unloading of "official" drives coming day after Christmas.
mgrobins
Post by mgrobins »
THanks for clearing that up. I didn't realise it was more an issue of Mike building in compatibility than LG changing their approach.
Seems Asus still have the better product and even a crossflashed LG is better than off the shelf. Given I've never touched my current drive since removing riplock and flashing it about 6 yrs ago I doubt I'll have any need with the new one I'm getting off Alex either.
spl147
Post by spl147 »
Any update on implementing this?
Sent from my iPhone Xs Max using Tapatalk Pro
