BLACK PANTHER ripping issues
st4evr
Re: BLACK PANTHER ripping issues
#16 Post by st4evr » Tue Dec 04, 2018 11:08 pm
audioguy wrote: Tue Dec 04, 2018 10:45 pm So if I cannot rip Mission Impossible Fallout, it is the fault of the Disc which mean I need to replace it? I got the following message on two different drives.
DEBUG: Code 0 at 3-&G:T%sH~_VhW_a:29396115
DEBUG: Code 0 at 3-&G:T%sH~_VhW_a:213134262
You've been advised on what to do for that error more than once already:
https://www.makemkv.com/forum/viewtopic ... 307#p64307
The process has not changed. Posting here that same error for every disc you get it on will not allow Mike to add support. You need to start submitting the dumps as instructed by Mike.
audioguy
#17 Post by audioguy » Wed Dec 05, 2018 3:21 pm
Fair enough and I have now done that.
pierceal
#18 Post by pierceal » Tue Dec 31, 2019 5:16 am
ridonkulous wrote: Wed Aug 01, 2018 8:36 am Just got my new LG drive sorted to accept UHD disks on my Mac but having real issues on my first attempt. MakeMKV throwing up error messages as follows on attempt just to make a backup copy:
MakeMKV v1.12.3 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE BE16NU50 1.01d" opened in OS access mode.
Backing up disc into folder "/Users/xxxxxxx/Movies/backup/BLACK_PANTHER"
Hash check failed for file 00045.m2ts at offset 5025294336, file is corrupt.
Hash check failed for file 00045.m2ts at offset 12652308480, file is corrupt.
Hash check failed for file 00045.m2ts at offset 12692416512, file is corrupt.
Hash check failed for file 00045.m2ts at offset 12692613120, file is corrupt.
Hash check failed for file 00045.m2ts at offset 12868184064, file is corrupt.
Too many hash check errors in file 00045.m2ts.
..and that's just a third of the way in.
A verdict?
Did this issue get resolved? I am having the same exact problem (Black Panther 4K at 00045.m2ts). I am running version 1.14.7
jonghotti
#19 Post by jonghotti » Tue Dec 31, 2019 6:52 pm
You’ve got a dirty disc my friend. I would encourage you to clean it thoroughly withs some LCD screen cleaner and a microfiber cloth and try that rip again.
