German Kid's Blu-Ray not opening
thefinn3
Post by thefinn3 » Tue Dec 04, 2018 7:20 am
HI, I am trying to rip "Augsburger Puppenkiste Urmel aus dem Eis / Urmel spielt im Schloss". Disc fails to open. Here is the log-file. Could You please help?
Thank You!
Debug log started at Tue Dec 4 07:16:33 2018 , written by MakeMKV v1.14.2 darwin(x64-release)
001005:0000 MakeMKV v1.14.2 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/rleidl/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW GX40N RQ00d" opened in OS access mode.
002010:0000 Optical drive "BD-RE ASMedia ASM105x 3.03d" opened in OS access mode.
DEBUG: Code 2365587456 at (/YVlr[>h*N'AVA5k:29394620
005050:0000 Evaluation version, 19 day(s) out of 30 remaining
DEBUG: Code 0 at -IbFTgc^Y5R&Ax,0:213140587
DEBUG: Code 0 at 3-&G:T%sH~_VhW_a:29401014
DEBUG: Code 2147483648 at -IbFTgc^Y5R&Ax,0:121265223
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=kyJ/D9PBDY/ChC+5HT0xU2bcBufBRTZy80fyRPGEBPlm+c/zoJuU8BcXUb6heMBWZuyPrGaRxR2zxYTw3BCVwRTVa/ZphT75x2a3pAe+apLsKh3XwLSQYwL1jyGaE2W8/XBvwycmP7wR3UqNxWPIGrlSzHThcMG9Rw==
DCE=4UJ35OXd4P4Q2Fr1E20yieZBO0iq6jtwBJtOIMtXyOB2KJZt5k2x6Qi7AaiZmYncF8AIXvxuKxBGxIIqkmfxSK0zkSVZmCx5eMwESHOL9toZ1OdcQ6V6eTrmzb3XimvOqbtzoW+H+s+teRGdb60u7MiiIpfo5zn0wg==
DISCID=DBCC6074BED6B1F248ABFBE8DF509A393524A592
003025:0000 Title #00071.mpls has length of 131 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00021.mpls has length of 1730 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00022.mpls has length of 1740 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00023.mpls has length of 1721 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00024.mpls has length of 1737 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00025.mpls has length of 1712 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00026.mpls has length of 1724 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00027.mpls has length of 1700 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00028.mpls has length of 1706 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00099.m2ts has length of 2 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 24 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00002.m2ts has length of 17 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 1730 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00071.m2ts has length of 66 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00072.m2ts has length of 65 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 8 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00300.m2ts has length of 60 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00101.m2ts has length of 889 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 1740 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 1721 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 1737 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 1712 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 1724 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00027.m2ts has length of 1700 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00028.m2ts has length of 1706 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00401.m2ts has length of 118 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00402.m2ts has length of 87 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00403.m2ts has length of 122 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
003025:0000 Title #00404.m2ts has length of 67 seconds which is less than minimum title length of 1800 seconds and was therefore skipped
Re: German Kid's Blu-Ray not opening
Post by Woodstock » Tue Dec 04, 2018 3:51 pm
Set your minimum title length to something less than half an hour (1800 seconds).
None of the titles on this disk are long enough, and are being ignored.
When dealing with TV episodes, a half-hour show will typically only be a 22-25 minute title.
