Incredibles 2
Re: Incredibles 2
You can download old versions (if you didn't keep a copy of them) from https://makemkv.com/download/old/
And you can have multiple versions installed, so long as they are in different program directories.
audioguy
Re: Incredibles 2
Post by audioguy »
I tried again using a different drive and it worked fine?????
eng050599
Re: Incredibles 2
Post by eng050599 »
audioguy wrote: Mon Dec 03, 2018 5:35 pm I tried again using a different drive and it worked fine?????
Unfortunately, there does appear to be an issue with some drives being able to read the discs. In the case of Blade Runner, and Batman Begins, I couldn't get successful rips. In both cases, I got Amazon to arrange a replacement, calling the disc unreadable.
The new discs ripped without issue. Trying it on another drive, may also be a valid option.
In this instance, I had no issues ripping Incredibles 2...once I figured out which of the 3 titles MakeMKV listed was the correct one.
EROracing
Re: Incredibles 2
Post by EROracing »
I'm having trouble right now ripping incredibles 2. It starts just fine but fails after like 10min. Any suggestions?
pcolmer
Re: Incredibles 2
Post by pcolmer »
eng050599 wrote: Sun Dec 09, 2018 7:32 am In this instance, I had no issues ripping Incredibles 2...once I figured out which of the 3 titles MakeMKV listed was the correct one.
How did you figure this out? Each title is showing a slightly different segment map but I have no idea what the actual difference would be between the three versions.
Thanks.
Philip
Re: Incredibles 2
Disney (who owns Pixar) uses a standard format. The play list that ends in 800.mpls is Engish. 801 and 802 have different languages for the titles and credits, usually Spanish and French, respectively.
