Community Blu-ray EXTRAS (DBG ASSERT errors)
eromin
Re: Community Blu-ray EXTRAS (DBG ASSERT errors)
Post by eromin »
Version 1.14.2 was just released, and it seems to have fixed the issue. I just tried Season 1 Disc 1, and all extras ripped without errors. I don't have time to do the other discs at the moment, but I wanted to give everyone following this thread an update.
4@ron=
Post by 4@ron= »
It WILL process the extras without any DEBUG errors, yay!! THANK YOU MAKEMKV. I've only checked the S1 D1 by the way.
However, the .mkv files are unplayable in VLC and make the software stick and crash a minute or more later. I've tried rebooting to no avail. I did manage to get the Blu-ray playing software on my mac to read the .mkv files just fine though and they DO play perfectly. I'm hoping that I can MKVtoolnix them into submission but I'm not terribly hopeful, I may just have to Handbrake them...
@eromin did you actually check the 'playability' of the .mkv files created? and if so, in what player?
Titles 13-19 all ripped fine as you suggested BUT for others following this strand do beware that something about these extras still throws VLC and possibly other video playing apps for a loop - I suppose we can now blame Mill Creek for the funky original encoding as I assume that MakeMKV at this point has done its work.
Thanks Mike!
4@ron=
Post by 4@ron= »
Okay, so again I believe MakeMKV has done it's due diligence and thus this message should probably be the last to take up space here on the MakeMKV forum but in the event that someone finds it's odd and possibly helpful elsewhere here tis.
I dropped the funky 'extra' .mkv's into MKVtoolnix and got another unplayable file. Here's the MediaInfo before/after (from MakeMKV extraction/repackage to post-MKVtoolnix repackaging)
After MakeMKV
Format : Matroska
Format version : Version 2
File size : 270 MiB
Duration : 3mn 58s
Overall bit rate mode : Variable
Overall bit rate : 9 509 Kbps
Writing application : MakeMKV v1.14.2 darwin(x64-release)
Writing library : libmakemkv v1.14.2 (1.3.5/1.4.7) darwin(x64-release)
Video
ID in the original source medium : 4113 (0x1011)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L3.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 3mn 58s
Bit rate mode : Variable
Bit rate : 9 312 Kbps
Maximum bit rate : 12.0 Mbps
Width : 720 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Original display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 (60000/1001) fps
Original frame rate : 29.970 (30000/1001) fps
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.450
Stream size : 265 MiB (98%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.601 NTSC
Transfer characteristics : BT.601
Matrix coefficients : BT.601
Original source medium : Blu-ray
POST-MKVtoolnix -- very weird file (still will NOT play in VLC!)
Format : Matroska
Format version : Version 1
File size : 92.0 MiB
Writing application : mkvmerge v29.0.0 ('Like It Or Not') 64-bit
Writing library : libebml v1.3.6 + libmatroska v1.4.9
SegmentSizeIsZero : Yes
IsTruncated : Yes
Video
Format : AVC
Width : 720 pixels
Height : 480 pixels
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) fps
Standard : NTSC
Color space : YUV
Bit depth : 8 bits
Language : English
Default : No
Forced : No
Any further thoughts anyone? Biggest differences I notice are file size (thought NO conversion of any kind was done), original frame rate 60fps?!?!, then some kind of "SegmentSizeIsZero" and "IsTruncated" display.... Bizarre. Next stop, Handbrake.
eromin
Post by eromin »
4@ron= wrote: Thu Dec 06, 2018 8:12 pm @eromin did you actually check the 'playability' of the .mkv files created? and if so, in what player?
Yes, I did test playability of all titles from S1 D1. They played with VLC on both my Windows 7 (VLC 3.0.3) and macOS 10.12.6 (VLC 2.2.6) machines with no issues. I've also tested them in Plex Media Player on Windows 7 and via the web client. I should have mentioned that in my last post. They're only standard def, so they don't look great, but they play.
4@ron=
Post by 4@ron= »
Looks like re-encoding them in Handbrake post-MakeMKV rip is a must for maximum compatibility on Mac VLC and Plex for Mac, works like a charm now!
Thanks again Mike & eromin!
eromin
Post by eromin »
I wonder what's going on with your files compared to mine. I didn't have to do anything with MKVToolNix or Handbrake to get mine to play. Glad you got them working.
crobc
Post by crobc »
Woodstock wrote: Fri Nov 02, 2018 1:08 am Are you having MakeMKV convert audio as you rip?
No. Like eromin, I rip the BDs 'straight' with no conversions.
UPDATE: I was able to use ver. 1.14.2 today on Win 8.1 to successfully "rip" from the decrypted/backup BD filesystem of the LPCM-only BD that would hang 1.12.3.
Perhaps I can try doing the same with the 5.1 containing BDs (I think I just received 1-2 more), in a few days.
(Unfortunately, I can't run 1.14.2 on my main PC with LinuxMint 17 since it gives "Application failed to initialize." But I won't complain about that since my Linux is a bit outdated.)
P.S. - Gee, I guess I spaced out and forgot about replying to this thread in Nov ;-)
