You can download old versions (if you didn't keep a copy of them) from https://makemkv.com/download/old/
And you can have multiple versions installed, so long as they are in different program directories.
Incredibles 2
Re: Incredibles 2
audioguy
Re: Incredibles 2
I tried again using a different drive and it worked fine?????
eng050599
Re: Incredibles 2
Unfortunately, there does appear to be an issue with some drives being able to read the discs. In the case of Blade Runner, and Batman Begins, I couldn't get successful rips. In both cases, I got Amazon to arrange a replacement, calling the disc unreadable.audioguy wrote: Mon Dec 03, 2018 5:35 pm I tried again using a different drive and it worked fine?????
The new discs ripped without issue. Trying it on another drive, may also be a valid option.
In this instance, I had no issues ripping Incredibles 2...once I figured out which of the 3 titles MakeMKV listed was the correct one.
EROracing
Re: Incredibles 2
I'm having trouble right now ripping incredibles 2. It starts just fine but fails after like 10min. Any suggestions?
pcolmer
Re: Incredibles 2
How did you figure this out? Each title is showing a slightly different segment map but I have no idea what the actual difference would be between the three versions.eng050599 wrote: Sun Dec 09, 2018 7:32 am In this instance, I had no issues ripping Incredibles 2...once I figured out which of the 3 titles MakeMKV listed was the correct one.
Thanks.
Philip
Re: Incredibles 2
Disney (who owns Pixar) uses a standard format. The play list that ends in 800.mpls is Engish. 801 and 802 have different languages for the titles and credits, usually Spanish and French, respectively.
