V14 doesn't seem to work
alansh
#1 Post by alansh » Thu Nov 08, 2018 2:17 pm
I upgraded to the new version 14 and wanted to rip a Midsomer Murders DVD.
MakeMKV found the disk and found the 2 titles. But then it started to increment something called CSS and just kept going. I abandoned it and tried again. Same result. Uninstalled it and reinstalled 12.3 and it works fine.
Something is amiss. Is there a test I can do for you to narrow down the issue?
regards
Alan
Crtguy
Re: V14 doesn't seem to work
#2 Post by Crtguy » Thu Nov 08, 2018 7:04 pm
I'm having the same problem. How do I retrieve 12.3? Thanks.
#3 Post by d00zah » Thu Nov 08, 2018 7:16 pm
Use 'Old Versions' link in sig.
st4evr
#4 Post by st4evr » Thu Nov 08, 2018 7:41 pm
For some reason Mike has not made 1.12.3 available in the archive yet.
Crtguy
#5 Post by Crtguy » Thu Nov 08, 2018 7:48 pm
Did a system reset and got 12.3.
smartieyoung
#6 Post by smartieyoung » Thu Nov 08, 2018 8:11 pm
i just did a system reset a few weeks ago.i havent noticed too many errors just when
i was trying to make a protected backup for the patriot to decrypt later gave me problems,still work in progress i guess
#7 Post by mike admin » Fri Nov 09, 2018 9:14 am
Should be fixed in 1.14.1
alansh
#8 Post by alansh » Mon Nov 12, 2018 10:06 am
Thanks Mike, I will try that
Alan
alansh
#9 Post by alansh » Tue Nov 20, 2018 2:25 pm
It worked for a while but now I get the same error (I just rebooted the machine). Gone back to 12.3 and that is working OK
gayled_it
#10 Post by gayled_it » Fri Nov 30, 2018 2:40 am
Hi. So I just downloaded version 1.14.1 because the previous version I was using had expired. Usually a new version has always reset the evaluation period but even though I uninstalled the previous version and downloaded this new one, when I go to open a disc, I get the error message saying my evaluation period has expired and I need to purchase a registration key in order to continue using the program. I've never encountered this issue after downloading the latest version release. Any help fixing this problem would be greatly appreciated. I tried using the current beta key but it says it is too old since it is the end of November. When will the new key be released?
#11 Post by Woodstock » Fri Nov 30, 2018 1:47 pm
gayled_it
#12 Post by gayled_it » Fri Nov 30, 2018 10:48 pm
Thank you. That did the trick.
