The Dark Knight Trilogy - The Dark Knight Rises
st4evr
Re: The Dark Knight Trilogy - The Dark Knight Rises
#16 Post by st4evr » Thu Nov 29, 2018 11:01 pm
mikesway wrote: Thu Nov 29, 2018 10:18 pm Does anyone know if ripping the 4K versions of the dark knight trilogy will also retain the IMAX parts of the movies? I know ripping a regular blu ray does not and am wondering if I should even bother trying to rip the 4K discs.
Yeah, you are making completely incorrect assumptions/observations or just don't have an understanding of how any of this works. That is NOT how BDs and their streams work. Or how ripping into an MKV container works for that matter either. IMAX scenes are not some special separate stream or separate part of the DI (Digital Intermediate) from where the BDs are authored, so let alone within the BD format.
mikesway
#17 Post by mikesway » Thu Nov 29, 2018 11:12 pm
So then why when I rip the blu ray movies are the IMAX sequences not retained? They still show as 2:35:1
#18 Post by Woodstock » Fri Nov 30, 2018 12:02 am
They're in there, just not as a separately-rendered bit of video. The whole movie is rendered in the same resolution throughout.
IMAX means nothing on the home theater front; You're getting a 1080p or 2160p video, where the non-IMAX parts were "upscaled" to match the IMAX in the theatre, and then back down to "home size" for the video release.
