[SOLVED] Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE'
plittlefield
#1 Post by plittlefield » Tue Nov 27, 2018 9:13 pm
I have been a happy user of this software for many years... keep up the great work.
However, the last three DVD discs I have used (Windtalkers, Dungeons & Dragons, The New World) have all given me the following error...
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0850..00C04 to device 'SG:dev_21:1'
...but have finished fine and created the required MKV file, which plays perfectly.
Is it my drive or is it the software?
Thanks,
Paul
MakeMKV v1.14.1 linux(x64-release)
Ubuntu 16.04
Re: Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE'
#2 Post by Woodstock » Tue Nov 27, 2018 9:20 pm
It really depends on when/where the error occurs in the process. Sometimes the error triggers MakeMKV to do something a bit differently to get around an access limitation.
I still see these occasionally while ripping. I ignore them as long as MakeMKV completes its tasks. If it doesn't, THEN I look at the particulars.
plittlefield
#3 Post by plittlefield » Wed Nov 28, 2018 10:39 pm
I am not sure exactly when it happens but it's at some point just before the saving process...
$ makemkvcon --minlength=1000 mkv disc:0 0 /tmp/
MakeMKV v1.14.1 linux(x64-release) started
Complex multiplex encountered - 14 cells and 7220 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Title #1 was added (14 cell(s), 1:55:22)
Title #2 has length of 133 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #3 has length of 20 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Title #4 has length of 144 seconds which is less than minimum title length of 1000 seconds and was therefore skipped
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0040..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0060..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0080..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..00A0..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..00C0..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..00E0..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0100..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0120..00C04 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0140..00C04 to device 'SG:dev_21:1'
Saving 1 titles into directory /tmp/
1 titles saved
Copy complete. 1 titles saved.
...the saving operation completes and the error has only started when I upgraded to the latest version 1.14.1 about a week ago.
It could just be coincidence... I have had the same BD Drive for many many years (performing thousands of operations) so it could be failing and I would not be surprised or sad.
What do you think?
smartieyoung
#4 Post by smartieyoung » Mon Dec 03, 2018 12:26 am
It could be that there is something going on with your drive if it has age to it.however i would say try to update makemkv to latest version and see if its still giving you the same error if it is.i would say it may be the drive.
plittlefield
#5 Post by plittlefield » Mon Dec 03, 2018 2:52 pm
Updated to 1.14.2 and the errors have gone :-)
cslibby
Re: [SOLVED] Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE'
#6 Post by cslibby » Wed Jan 02, 2019 3:46 am
I had the same problem in 1.14.2. I solved it by locating the ccextractor program and going into preferences and selecting advanced preferences and then under the advanced tab which shows up, I put in the path to ccextractor. /usr/bin/ccextractor
It was giving me an /usr/bin/mmccextr message and that program is not the name if you install ccextractor on UBUNTU 14 Desktop the command is ccextractor. It seems to work on a brand new movie I just purchased.
captdave
#7 Post by captdave » Tue Feb 05, 2019 11:21 pm
I downloaded the Makemkv program again. I was using 1.14.2 for Mac. It was the same version as the one I was running that was giving me the "ILLEGAL REQUEST" errors. The I ran the replacement version of makemkv the "ILLEGAL REQUEST" errors no longer appeared and the program starting working again. Try downloading it again and replace your existing app.
RiotNrrrd
#8 Post by RiotNrrrd » Sat Mar 16, 2019 2:35 am
I downloaded the MakeMKV program again. I was using 1.14.2 for Mac. It was the same version as the one I was running that was giving me the "ILLEGAL REQUEST" errors. The I ran the replacement version of makemkv the "ILLEGAL REQUEST" errors no longer appeared and the program starting working again. Try downloading it again and replace your existing app.
Hello all. My first post here. I have a USB external HL-DT-ST BHN16S55 drive with 1.02 firmware. Using 1.14.3 on a Mac mini running El Capitan 10.11.6.
I went to Fry's and bought Incredibles 2 on UHD and decided to try it out as the guinea pig for seeing if I can rip UHD titles with this drive to my RAID.
But almost as soon as I set MakeMKV loose on it, I got these errors - 5 sets of them.
(The weird thing is, I didn't even select the "Decrypt video files" option. Thought I would try it un-decrypted first, just for grins. Should I have checked it instead?)
Here are the errors. Should I worry? Is my drive revoked already?? :shock:
MakeMKV v1.14.3 darwin(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Optical drive "BD-RE HL-DT-ST BD-RE BH16NS55 1.02d" opened in OS access mode.
Backing up disc into folder "/Volumes/Media/Video/Movies/Incredibles.2.2018.COMPLETE.UHD.UNDECRYPTED/INCREDIBLES_2"
Downloading latest SDF to /Users/admin/Library/MakeMKV ...
Using LibreDrive mode (v05 id=067EFCA8EA7E)
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..014C9CCAEFF08DC43E1933DA78B626009B7 to device 'IoKit:IOBDServices:c65f0213b607d79d:HL-DT-ST BD-RE BH16NS55 1.02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0AA17BD8EBE4FEB6FDB6801DEF36106050D to device 'IoKit:IOBDServices:c65f0213b607d79d:HL-DT-ST BD-RE BH16NS55 1.02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..05CF45F4B7C85C735D38C86B02005B03242 to device 'IoKit:IOBDServices:c65f0213b607d79d:HL-DT-ST BD-RE BH16NS55 1.02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0909A84EB43983991BE590FFFE445AEC1F9 to device 'IoKit:IOBDServices:c65f0213b607d79d:HL-DT-ST BD-RE BH16NS55 1.02'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occurred while issuing SCSI command A30..00200740100720..0864B47D265D62AC508E29FE10C7E8CC01B to device 'IoKit:IOBDServices:c65f0213b607d79d:HL-DT-ST BD-RE BH16NS55 1.02'
Hash check failed for file 00162.m2ts at offset 562685952, file is corrupt.
Hash check for /BDMV/STREAM/00162.m2ts : 0.03% corrupt, 99.94% correct, 99.97% checked.
Hash check failed for file 00159.m2ts at offset 216852480, file is corrupt.
Hash check for /BDMV/STREAM/00159.m2ts : 0.01% corrupt, 99.98% correct, 99.99% checked.
Encountered 2 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/...
Backup done but 2 files failed hash check
waitaminute
#9 Post by waitaminute » Mon Nov 27, 2023 9:58 pm
Restarting MakeMKV worked for me
