FOR A FEW DOLLAR MORE BD+
legluondunet
Post by legluondunet »
I own this BLURAY:
$ bd_info blu-ray_movie.iso
Using libbluray version 1.0.2
syntax error: line 1
bad entry at or around line 1
mmc_device_linux.c:175: No MMC drive mounted to blu-ray_movie.iso
aacs.c:1371: aacs_get_vid() failed
dec.c:217: BD+ initialization failed (no AACS ?)
Volume Identifier   : FORAFEWDOLLARSMORE_F2
BluRay detected     : yes
First Play supported: yes
Top menu supported  : yes
HDMV titles         : 1
BD-J titles         : 89
UNSUPPORTED titles  : 0
BD-J detected       : yes
Java VM found       : yes
BD-J handled        : yes
BD-J organization ID: 7fff646c
BD-J disc ID        : 0000000000000000000000000000019c
AACS detected       : yes
libaacs detected    : yes
Disc ID             : B4FEB5ED4477C4471FD5814AF3F6E302DA6A1B0B
AACS MKB version    : 17
AACS handled        : yes
BD+ detected        : yes
libbdplus detected  : yes
BD+ handled         : no
Application info:
  initial mode preference : 2D
  3D content exists       : No
  video format            : ignored (0x0)
  frame rate              : ignored (0x0)
  provider data           : '          Deluxe Digital Studios'
Disc library metadata:
Metadata file       : bdmt_eng.xml
Language            : eng
Disc name           : For A Few Dollars More
Alternative         : <undefined>
Disc #              : 1/1
TOC count           : 90
	Title 1: For A Few Dollars More
	Title 2: placeholderFiller
	Title 3: placeholderFiller
	Title 4: placeholderFiller
	Title 5: placeholderFiller
	Title 6: placeholderFiller
	Title 7: placeholderFiller
	Title 8: placeholderFiller
	Title 9: placeholderFiller
	Title 10: placeholderFiller
	Title 11: placeholderFiller
	Title 12: placeholderFiller
	Title 13: placeholderFiller
	Title 14: placeholderFiller
	Title 15: placeholderFiller
	Title 16: placeholderFiller
	Title 17: placeholderFiller
	Title 18: placeholderFiller
	Title 19: placeholderFiller
	Title 20: placeholderFiller
	Title 21: placeholderFiller
	Title 22: placeholderFiller
	Title 23: placeholderFiller
	Title 24: placeholderFiller
	Title 25: placeholderFiller
	Title 26: placeholderFiller
	Title 27: placeholderFiller
	Title 28: placeholderFiller
	Title 29: placeholderFiller
	Title 30: placeholderFiller
	Title 31: placeholderFiller
	Title 32: placeholderFiller
	Title 33: placeholderFiller
	Title 34: placeholderFiller
	Title 35: placeholderFiller
	Title 36: placeholderFiller
	Title 37: placeholderFiller
	Title 38: placeholderFiller
	Title 39: placeholderFiller
	Title 40: placeholderFiller
	Title 41: placeholderFiller
	Title 42: placeholderFiller
	Title 43: placeholderFiller
	Title 44: placeholderFiller
	Title 45: placeholderFiller
	Title 46: placeholderFiller
	Title 47: placeholderFiller
	Title 48: placeholderFiller
	Title 49: placeholderFiller
	Title 50: placeholderFiller
	Title 51: placeholderFiller
	Title 52: placeholderFiller
	Title 53: placeholderFiller
	Title 54: placeholderFiller
	Title 55: placeholderFiller
	Title 56: placeholderFiller
	Title 57: placeholderFiller
	Title 58: placeholderFiller
	Title 59: placeholderFiller
	Title 60: placeholderFiller
	Title 61: placeholderFiller
	Title 62: placeholderFiller
	Title 63: placeholderFiller
	Title 64: placeholderFiller
	Title 65: placeholderFiller
	Title 66: placeholderFiller
	Title 67: placeholderFiller
	Title 68: placeholderFiller
	Title 69: placeholderFiller
	Title 70: placeholderFiller
	Title 71: placeholderFiller
	Title 72: placeholderFiller
	Title 73: placeholderFiller
	Title 74: placeholderFiller
	Title 75: placeholderFiller
	Title 76: placeholderFiller
	Title 77: placeholderFiller
	Title 78: placeholderFiller
	Title 79: placeholderFiller
	Title 80: placeholderFiller
	Title 81: placeholderFiller
	Title 82: placeholderFiller
	Title 83: placeholderFiller
	Title 84: placeholderFiller
	Title 85: placeholderFiller
	Title 86: openingSequence1 BDJO
	Title 87: openingSequence2 BDJO
	Title 88: bootstrap_BDJO
	Title 89: updaterPlaceholder_BDJO
	Title 90: Reset
Thumbnail count     : 2
MAKEMKV ca not read it, It gives me this error message:
Fichier de vidange AACS enregistré sous MKB_v17_For_A_Few_Dollars_More_4818.tgz
La clé de volume est inconnue pour ce dique - la vidéo ne peut être décryptée
DEBUG: Code 0 at 2!sV;+`7[8z8bem :29396138
DEBUG: Code 0 at 2!sV;+`7[8z8bem :213134377
Échec de l'ouverture du disque
Thank you for your help.
Config:
Ubuntu 18.04
MAKEMKV 1.14.1
Re: FOR A FEW DOLLAR MORE BD+
This does not appear to be a BD+ issue, and the AACS version (17) should not be a factor with MakeMKV, if you're ripping from the disk itself.
Ripping from an ISO, however, key information needed to decode the encryption is not available to MakeMKV.
This message may help: viewtopic.php?f=10&t=17162&p=61117&hilit=discatt#p61117
