conversion speed / execution time
g'ner
Post by g'ner » Wed Jul 28, 2010 5:46 pm
Hi I just built a new win7 media box and last night I converted a dvd iso to individual episode mkv files and I noticed that both my new box and old box took about the same time to convert the similar tasks (dvds iso to mkv files). Shouldn't the new box be x times faster. Is the the conversion time throttled by the sw? How can I speed this up?
Old Box spec
win xp
pentium 3 1.5ghz single core
758 megs of ram
media on a 1tb drive esata through a pci card (1.5sata?)
used 100% of resources took convert ~10min execution time
New Box
win7 64bit
AMD|ATH II X2 250 AM3 3.0ghz dual core
4gigs of ram
media on 1tb esata through on board esata (1.5sata?)
low percentage of resources ~20 to 25% of resources took ~10min execution time
gremlin190
Re: conversion speed / execution time
Post by gremlin190 » Thu Jul 29, 2010 2:51 am
I think it's actually due to the speed of your bluray drive. Please post here your findings so we can keep everything together.
http://www.makemkv.com/forum2/viewtopic.php?f=1&t=1325
g'ner
Post by g'ner » Thu Jul 29, 2010 6:19 am
everything was an iso (image), so no rom(bl/dvd) was a factor. I am seeing better performance tonight thou, around 5-7 min. It must just depend on the iso. I am also starting to think disk write speed is the common bottle neck.
setarip_old
Post by setarip_old » Thu Jul 29, 2010 6:42 am
Hi!
Add a second physical hard drive and read from one drive and write to the other for a drastic reduction in time required...
[/color]
MilesAhead
Post by MilesAhead » Thu Jul 29, 2010 9:44 pm
setarip_old wrote:Hi!
[/color]
I second that. Instead of adding internal drives I added a USB 3.0 dual port card and USB Superspeed docking stations. 6 Gb/sec internal drives stuck in the docks operate at full speed. Muxing flies.
Krobar
Post by Krobar » Fri Jul 30, 2010 8:32 am
I prefer ESATA. Not sure what the performance penalty is with HDs but with a BR drive I saw 10-15% loss with USB, no performance loss with ESATA.
MilesAhead
Post by MilesAhead » Sat Jul 31, 2010 5:25 am
Krobar wrote:I prefer ESATA. Not sure what the performance penalty is with HDs but with a BR drive I saw 10-15% loss with USB, no performance loss with ESATA.
You must be talking USB 2.0. I get sequential read from WD 6 Gb/sec 1 TB HD in USB 3.0 dock at 143 MB/sec Crystal Diskmark. The muxing doesn't slow me down. :)
PaulB
Post by PaulB » Mon Jan 03, 2011 4:52 pm
I know this thread was last updated some time ago but I just wanted to understand the main pinch point for performance.
MakeMKV certainly seems pretty fast. Processing a folder structure that had been ripped by AnyDVD; CPU and memory didn't seem to be the bottle neck so I can only assume that disk IO is the main rate determing factor? For ultimate performance reading from an SSD disk and writing to an SSD disk which result in ultimate performance rather than improvement to any other component?
Paul
