DTS-Audio
Re: DTS-Audio
Second the request for any advice about possibly using these Audio Streams, but other
than these and BD+, the efforts here are becoming pretty exceptional.
Re: DTS-Audio
I've had no problem extracting the DTS core of a DTS-HD-MA stream using MakeMKV
Re: DTS-Audio
It's a restriction of the BETA-Version, I think (the log says it). But I have not found any possibility to buy the Full version ...
I am ready to pay a appropriate price for good software.
- Contact:
Re: DTS-Audio
DTS is supported in a sense that only DTS core is extracted. Any problem with DTS (except for "DTS-HD audio") is a bug. LPCM is not supported currently but, will be supported soon. If you have a disc with unsupported "DTS-HD audio" track, please let us know the name of the disc.
Re: DTS-Audio
Hi Mike,
thank you for answer. Today I have one example: Shine A Light (Stones, Scorsese). Only the extras have audio. (simply stereo)
Some more Blu-rays I will test as soon as possible.
[update] next try: "King Kong" with Extended Edition DTS (the german track) is not supported
next: "Wanted"
Log: Stream #40 of type 'DTS-HD second audio' in file 00009.m2ts was skipped, since it is not supported in BETA version
Stream #41 of type 'DTS-HD second audio' in file 00009.m2ts was skipped, since it is not supported in BETA version
next: "Wanted"
Re: DTS-Audio
Hi...
I am a german Guy to.
You can use DTS without any Problems. But only 1 Stream.
I make it with Akte X (the X Files). Only took the second Audio an you will have the DTS as Audio Track in the MKV.
- Contact:
Re: DTS-Audio
I see the confusion. in DTS HD a single audio track is represented by two streams - core audio and extension. Core audio contains 5.1 audio and extension brings it to 7.1 or loseless. MakeMKV skips extension stream (second audio) but not the core audio. Your produced MKV file should have DTS stream in it.OnkelP wrote:Hi Mike,
next: "Wanted"
Re: DTS-Audio
@ acer2k,
thanks a lot. But in the future it would be nice, to get alternitive languages. It's the intention of programmer, I think.
@ mike,
thank you for explanation. I did not know that an will try it again.
@ mike,
Re: DTS-Audio
The Pride and Prejudice Blu-ray discs give a "Stream #1 of type 'DTS-HD audio' in file ....m2ts was skipped, since it is not supported in BETA version" message (this is on GNU/Linux). This leads to the MKV only having the "audio description" AC3 audio, which is no doubt wonderful for the vision impaired, but less than ideal for those who don't need to be told that someone is pausing in the doorway.mike admin wrote:DTS is supported in a sense that only DTS core is extracted. Any problem with DTS (except for "DTS-HD audio") is a bug. LPCM is not supported currently but, will be supported soon. If you have a disc with unsupported "DTS-HD audio" track, please let us know the name of the disc.
I'm unsure from the quoted text whether this is something that will be supported soon (as per the message from the program), or a bug that may be fixed even sooner. :)
