st4evr
Post by st4evr » Mon Nov 19, 2018 10:57 pm
blublbub wrote: Mon Nov 19, 2018 7:40 pm Hi
I have an Asus BC-12D2HT which has FW 3.01. On top of that my PCs don't offer IDE mode, just RAID instead of AHCI.
Is there any way I can downgrade this sucker? If not which drives can I buy that should work out of the box with UHD discs for MakeMKV?
Already discussed in detail here:
viewtopic.php?f=16&t=17034&p=66517&hili ... 2HT#p66517
And here:
viewtopic.php?f=16&t=18251
And here:
viewtopic.php?f=16&t=18346
And in clearly marked post where members are selling ready-to-go drives. You have choices.
Dan-O
Post by Dan-O » Tue Nov 20, 2018 3:17 pm
Just wanted to post another semi success story (fingers crossed that it worked, but I can't test it until later today!)
Drive: Asus BW-16D1HT (BH16NS40) with 3.3
- Create Win 7 PE on a USB (1GB USB was fine for this, in case anyone is worried about size)
- Copied DOSFLASH32 (all files) and 3.02 firmware to the USB (GOOD 3.02, not slyly-updated 3.02 from Asus)
- had to set SATA configuration to ATA on this machine (Dell Precision) via BIOS, as expected.
- Disconnected all drives in the PC and only plugged Asus drive into the primary SATA port
- Booted from USB into Win7 PE
- ran DOSFLASH32_BH16NS40, and it saw my drive. Selected Read Flash. Made multiple copies ;)
- Ran the EEPROM data mover and saved the new flash file. Made multiple copies ;)
- ran DOSFLASH32_BH16NS40 again... ERROR. Problem loading portio32.sys ("Oh no!")
- remembered that I already had DOSFLASH32_BH16NS40 running ;) can't run two instances at the same time, silly rabbit.
- Selected Erase Flash in DOSFLASH32_BH16NS40. Point of no return?
- Selected Write Flash in DOSFLASH32_BH16NS40. Used updated file from EEPROM data mover.
- 30 seconds later, flash was done. Closed and re-opened DOSFLASH32_BH16NS40. Confirmed firmware now shows 3.02.
Asus BW-16D1HT (BH16NS40) with 3.02 is now ready to test. Hoping it goes well. :D
EDIT: ripping ZOMBI: Dawn of the Dead now 8)
tds3819
Post by tds3819 » Tue Nov 20, 2018 7:48 pm
Can I get some assistance for the necessary FW edits for my BW-16D1HT? I've attached the dump of my current. Or just point me in the right directions. Thanks!
tds3819
Post by tds3819 » Tue Nov 20, 2018 10:57 pm
tds3819 wrote: Tue Nov 20, 2018 7:48 pm Can I get some assistance for the necessary FW edits for my BW-16D1HT? I've attached the dump of my current. Or just point me in the right directions. Thanks!
Nevermind I think i got it working. Well at least I reflashed it and it shows the earlier version. Unfortunately dont have any UHD discs yet to try it out on.
Post by MartyMcNuts » Tue Nov 20, 2018 11:51 pm
@tds3819
Here you go. A fresh ASUS BW-16D1HT 3.02 firmware created using your 3.03 firmware dump. Once you get this installed, let us all know how you go with UHD ripping!!
tds3819-ASUS-BW-16D1HT-3.02.bin.zip
wippet
Post by wippet » Wed Nov 21, 2018 2:19 am
Dan-O wrote: Tue Nov 20, 2018 3:17 pm Just wanted to post another semi success story (fingers crossed that it worked, but I can't test it until later today!)
Thanks Dan-O I have a BH16NS40 that wasn't a CS50 version so I'll grab one of these Asus's since it looks like they're still working. Cheers for a recent update!
Colindo
Post by Colindo » Sat Nov 24, 2018 3:22 pm
Your method worked for me like a charm. Used the firmware that MartyMcNuts gave me and used Erase and Write Flash in the Windows 7 PE.
dacman
Post by dacman » Mon Nov 26, 2018 3:06 am
I don’t feel confortable messing with my system to get this to work. Anyone willing to do this for me if I ship them my drive? I have an Asus BW-16D1HT with firmware version 3.03.
st4evr
Post by st4evr » Mon Nov 26, 2018 6:22 am
dacman wrote: Mon Nov 26, 2018 3:06 am I don’t feel confortable messing with my system to get this to work. Anyone willing to do this for me if I ship them my drive? I have an Asus BW-16D1HT with firmware version 3.03.
There’s already plenty of that. View the links provided here:
viewtopic.php?f=16&t=18411
These are clearly marked posts from members that provide such services.
Post by Billycar11 » Mon Nov 26, 2018 10:16 am
sure check out my thread viewtopic.php?f=16&t=17831 i will flash it for you for $25 Email me Billycar5924@gmail.com
wippet
Post by wippet » Tue Nov 27, 2018 11:35 am
Just picked up an Asus BC-12D2HT but even with Firmware 3.01 I'm still getting "No disc inserted" unfortunately. Will give a firmware flash a go tomorrow and cross my fingers.
OS device name: H:
Manufacturer: ASUS
Product: BC-12D2HT
Revision: 3.01
Firmware date: 2117-11-15 19:26:
Bus encryption flags: 1E
Highest AACS version: 21
Edit: Ho...ly...smokes. Flashed the BC-12D2HT 3.01 to a BW-16D1HT 3.00 and currently backing up my UHD copy of Coco. Going at ~7MB/s which seems down on everyone else, but extremely happy that it's working at all. Got a sale out of me, and thanks to the community and the pages of advice from everyone :D
rhonielu
Post by rhonielu » Wed Nov 28, 2018 8:33 pm
Hello All,
I have an LG WH16NS40 with 1.03 firmware and I am trying to downgrade the firmware to v1.02. I have dumped the firmware using DosFlash software. I attaching the firmware dump.
Can someone please help me with downgrading firmware to 1.02 by incorporating the data from 1.03 to 1.02?
Post by Billycar11 » Wed Nov 28, 2018 10:52 pm
rhonielu wrote: Wed Nov 28, 2018 8:33 pm Hello All,
attachment deleted to save forum space.
rhonielu
Post by rhonielu » Thu Nov 29, 2018 12:50 pm
Thank you, Mr Billycar11. :D
Jobber72
Post by Jobber72 » Sat Dec 01, 2018 1:39 pm
giomania wrote: Thu May 03, 2018 7:47 pm Here is the document, in case it helps anyone else: https://drive.google.com/open?id=1EvYk8 ... EuF3y9qzwx
Thanks to @TeddyRaspin and the community for the great tips and resources.
Thanks a million for your nice document. Together with that and the original "100% Firmware Downgrade etc..." guide it was a breeze to downgrade my brand new ASUS BW-16D1HT from 3.03 (bought it this week, manufacturing date is somewhere in May) to 3.01. Before flashing I used a HEX editor to check that the parts that needed to go over had indeed been done.
The only weird thing: booting Windows7. (normally Opensuse Tumbleweed) ;-)
[update]: Just successfully ripped the first UHD BR.
Great stuff!
