Batman Begins blu-ray
Fortissimo
Post by Fortissimo »
I can't back up my Batman Begins blu-ray... with either of my two drives. Before someone tells me it's a bad disc, I also tested a library copy as well as Netflix. All three of them, on both drives, give me the same problem. (By the way, I do see that v.1.14.1 is out... I had skipped over 1.13 because it was buggy. I will try this next, although I don't have my hopes up because this problem is from an old Blu-Ray and only seems to be with this particular Blu-Ray.)
Debug log started at Mon Nov 19 19:49:06 2018 , written by MakeMKV v1.12.2 win(x64-release)
001005:0000 MakeMKV v1.12.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\user/MakeMKV_log.txt
005075:0000 The new version 1.14.1 is available for download at http://www.makemkv.com/download/
DEBUG: Code 2365587456 at #JEH3khy]yJ.Vdvo:121271065
DEBUG: Code 2147483648 at #JEH3khy]yJ.Vdvo:29396483
DAFD=PAAAADAAAAEABDQEEEgADAQ==
DCE=92HuO5xg4n6URWY2DQRNV2mTQtOYtczIUqheRuJK4YXcGgvtK4bs2jRkxREcSqSHIHO0+39YrVuSjnWBFqAvJZcJRUzC/r14NCmAAP7h+cWXezmVkzTqKndmZfIi1OGDZPB41CE3wQtom2L6jOgamvuKyf2/ZgvWjQ==
DCE=LXqzczMawVXyZ3FxZlQmtftSNQb9NN74qAoqeOysRgRwKVzugVhW+m7forghgXxiqLJ8VVfX8ZBgvYjXR4k64UnzwqhDiCmfQ85WWHe5Qyd7/dpHjjxJSxOo9/0+NlbAG+eVWWa11SlEWm8PN/UUtT1bQk7wnjwGGQ==
DISCID=173EC598F41CC7B5A66DAAA99E2418DC0E671F99
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00010.m2ts was added as title #1
003025:0000 Title #00029.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00054.m2ts was added as title #2
003307:0000 File 00055.m2ts was added as title #3
003307:0000 File 00056.m2ts was added as title #4
003307:0000 File 00057.m2ts was added as title #5
003307:0000 File 00058.m2ts was added as title #6
003025:0000 Title #00065.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory A:/Movies
004001:0000 Forced subtitles track #3 turned out to be empty and was removed from output file
004001:0000 Forced subtitles track #5 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
DCE=s8vI+xNY6NHLo1T7DyU085mgBCyRUB6x1DKSAU+QBUkKMKpqr5WvwXnOTNbnJwKHI0MkJsV9bV13FkKm4742Z2uYcHybUNvrlJ15/4iEqr1e8LWtOdq5Bac6l3DdE5L+qArTMc2hGpJEJTGQhFJF6Q6oYwf5He/2cg==
DCE=Nzc3NzdwDJ2rb8Rz2gpRVdwD6YphJaUB3TKHf/JFd0ujVtIOGx5r7tqu9CSIpy+kmIU+XEzfmXKc+OIw3rcwjTul3a4+JXkCkiyTDH67H8/0zQbub7NvZYt9d2fvs6/YrVH2AAfMFRbC2aD1n/DeatDyJfi52I9rsg==
DISCID=4294987909B3FFB02A351BC7B6AC244292071870
003025:0000 Title #00013.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.mpls has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00022.mpls was added as title #0
003025:0000 Title #00024.mpls has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.mpls has length of 72 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00026.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00027.mpls has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00028.mpls has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.mpls has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00030.mpls has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00031.mpls was added as title #1
003025:0000 Title #00032.mpls has length of 78 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.mpls has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.mpls has length of 111 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00012.mpls was added as title #2
003025:0000 Title #00050.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00051.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00072.mpls was added as title #3
003307:0000 File 00057.mpls was added as title #4
003025:0000 Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00000.m2ts was added as title #5
003025:0000 Title #00001.m2ts has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00013.m2ts has length of 73 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00016.m2ts was added as title #6
003307:0000 File 00017.m2ts was added as title #7
003307:0000 File 00018.m2ts was added as title #8
003307:0000 File 00021.m2ts was added as title #9
003307:0000 File 00022.m2ts was added as title #10
003307:0000 File 00023.m2ts was added as title #11
003307:0000 File 00024.m2ts was added as title #12
003307:0000 File 00025.m2ts was added as title #13
003307:0000 File 00026.m2ts was added as title #14
003307:0000 File 00027.m2ts was added as title #15
003025:0000 Title #00003.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00009.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00028.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00029.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00038.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00040.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00083.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00084.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00085.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00086.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00087.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00088.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00089.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00090.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00091.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00092.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00093.m2ts has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00094.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00095.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00096.m2ts has length of 28 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00097.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00098.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00102.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00103.m2ts has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00104.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00105.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00106.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00107.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00108.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00109.m2ts has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00110.m2ts has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00111.m2ts has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00112.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00113.m2ts has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00015.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00116.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00117.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00120.m2ts was added as title #16
003309:0000 Title 00119.m2ts is equal to title 00072.mpls and was skipped
003025:0000 Title #00121.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00122.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001003:0020 DEBUG: Code 3221225628 at IgQmA{Z\!0JJb^S}Ly^RoZ~^:213130398
001003:0020 DEBUG: Code 3221225628 at /P_{g?dpR?wxUPc<:29393953
001003:0020 DEBUG: Code 101067008 at ]p8h%iw6q@=GL92,:121269823
002003:0000 Error 'OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '6820657152'
001003:0020 DEBUG: Code 2147483670 at IgQmA{Z\!0JJb^S}Ly^RoZ~^:213130398
001003:0020 DEBUG: Code 2147483670 at /P_{g?dpR?wxUPc<:29393953
002003:0000 Error 'OS error - {Verifying Disk} The media has changed and a verify operation is in progress so no reads or writes may be performed to the device, except those used in the verify operation' occurred while reading '\Device\CdRom2' at offset '6820657152'
DEBUG: Code 2147483670 at ,i4-.2g.]3n$zk0ZB=:213130904
001003:0020 DEBUG: Code 2147483670 at ,i4-.2g.]3n$zk0ZB=:121262969
001003:0020 DEBUG: Code 3221225490 at IgQmA{Z\!0JJb^S}Ly^RoZ~^:213130398
001003:0020 DEBUG: Code 3221225490 at /P_{g?dpR?wxUPc<:29393953
002003:0000 Error 'OS error - {Wrong Volume} The wrong volume is in the drive. Please insert volume hs into drive hs' occurred while reading '\Device\CdRom2' at offset '6820657152'
DEBUG: Code 3221225490 at ,i4-.2g.]3n$zk0ZB=:213130904
001003:0020 DEBUG: Code 3221225490 at ,i4-.2g.]3n$zk0ZB=:121262969
DEBUG: Code 3221225653 at ,i4-.2g.]3n$zk0ZB=:213130904
001003:0020 DEBUG: Code 3221225653 at ,i4-.2g.]3n$zk0ZB=:121262969
001003:0020 DEBUG: Code 0 at n6_l4"9@ad(W>C?k_j*r:121263176
001003:0020 DEBUG: Code 0 at wz7oQ0FT$kUdK(c42RCM:29394068
001003:0020 DEBUG: Code 0 at n6_l4"9@ad(W>C?k_j*r:29394551
001003:0020 DEBUG: Code 3330399 at n6_l4"9@ad(W>C?k_j*r:29393286
001003:0020 DEBUG: Code 0 at O}/})]dH|,$|uPs991YUL:213135550
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 2 to file A:/Movies/Batman (1) Begins (2005) (2.6.3) [1080p].mkv
Encountered 19 unclassified errors
error=0x06062900 count=1 name=Scsi error - UNIT ATTENTION:POWER ON, RESET, OR BUS DEVICE RESET OCCURRED
error=0x80000016 count=1 name=OS error - {Verifying Disk} The media has changed and a verify operation is in progress so no reads or writes may be performed to the device, except those used in the verify operation
error=0xC0000012 count=4 name=OS error - {Wrong Volume} The wrong volume is in the drive. Please insert volume hs into drive hs
error=0xC000009C count=3 name=OS error - STATUS_DEVICE_DATA_ERROR
error=0xC00000B5 count=10 name=OS error - {Device Timeout} The specified I/O operation on hs was not completed before the time-out period expired
005004:0080 0 titles saved, 1 failed
Application exited at Tue Nov 20 03:53:46 2018
Has anyone else experienced the same problem, or is this just a huge coincidence / the universe conspiring against me?
Re: Batman Begins blu-ray
Do the errors occur at the same point (file and offset), or do they change between runs?
Are both of your drives external USB powered?
The errors shown in your log are consistent with the drive spinning too fast for the available power, shutting down, and then resetting. This will usually happen in a long file, because the drive slows down when it transitions between files, and speeds up as it gets toward the outer tracks of the DVD/BD.
