A List of Discs that Fail to Rip
Krobar
Re: A List of Discs that Fail to Rip
1.5.6 is a big improvement. It seems to have fixed all itles that caused MakeMKV to crash and a few others. None of the discs that still dont rip crash MakeMKV anymore.
Krobar
A few more added although compatability is overall very good with current version.
Krobar
More Added.
Please could you move this to the DVD Error Reports forum (Forum did not exist when I started this thread).
Mr_Orange
Is Die Hard 4.0 region 2 still a problem disc?
I am unable to rip it using an LG DVD drive.
TIA.
TIA.
Since the topic you're replying to is almost 9 years old, and covers version 1.5.6 (we're on 1.14.4 now), I'd say this topic is well beyond "obsolete".
If you're experiencing rip errors, please read here first!
Mr_Orange
I came to the thread via Google and am new to the forum so did not immediately notice how old the thread was.Woodstock wrote: Sun Jul 14, 2019 12:43 pm Since the topic you're replying to is almost 9 years old, and covers version 1.5.6 (we're on 1.14.4 now), I'd say this topic is well beyond "obsolete".
Be that as it may, I am using version 1.14.4 and cannot successfully rip Die Hard 4.0, region 2 DVD.
I'll have a read of the thread you linked me to, thank you.
Grauhaar
You should provide an Debug Log: https://www.makemkv.com/faq/item/8
Good Luck
Mr_Orange
Here is the output from the Debug Log:Grauhaar wrote: Mon Jul 15, 2019 11:04 am You should provide an Debug Log: https://www.makemkv.com/faq/item/8
Debug log started at Mon Jul 15 13:01:07 2019 , written by MakeMKV v1.14.4 win(x64-release)
001005:0000 MakeMKV v1.14.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\piers.james/MakeMKV_log.txt
No SDF v05c: HL-DT-ST_DVDRAM_GH24NS95_RN00_201209201126_KTTC9RH0636
SDF id v05c: HL-DT-ST_DVDRAM_GH24NS95_RN00_201209201126_KTTC9RH0636
No auto SDF v05c: HL-DT-ST_DVDRAM_GH24NS95_RN00_201209201126_KTTC9RH0636
DEBUG: Code 0 at }yJ2^mTS!\xYjfa7w:29395540
DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:121261773
DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:29393792
001003:0020 DEBUG: Code 100864261 at Lt[RKo\%gO`]aK^U:213137574
001003:0020 DEBUG: Code 100864261 at e7]KVtM7J@G@6#ej:121262417
001003:0020 DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:29395701
001003:0020 DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:121261934
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
001003:0020 DEBUG: Code 0 at d'Sj)YmyXNhv|Y:213136953
001003:0020 DEBUG: Code 0 at d'Sj)YmyXNhv|Y:121261819
001003:0020 DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:29394965
003028:0000 Title #1 was added (32 cell(s), 1:48:07)
003025:0000 Title #2 has length of 218 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #3 has length of 31 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #4 has length of 21 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #5 has length of 98 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #6 has length of 66 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #7 has length of 468 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #8 has length of 270 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003025:0000 Title #9 has length of 347 seconds which is less than minimum title length of 600 seconds and was therefore skipped
003014:0000 Title #9 in broken titleset was skipped
001003:0020 DEBUG: Code 233 at 2FeL0Ps/d7nKYA9IwJWokiNo:0
005014:0000 Saving 1 titles into directory E:/incoming/temp/hb
001003:0020 DEBUG: Code 3221225628 at 2)Me.@84\|r*6W&&&97..1e^:29394091
001003:0020 DEBUG: Code 3221225628 at e7]KVtM7J@G@6#ej:121262417
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26624'
DEBUG: Code 3221225628 at ueX$([U\RyQWMQ{AgE:121262693
001003:0020 DEBUG: Code 3221225628 at ueX$([U\RyQWMQ{AgE:29394758
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '26624'
DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:121262693
001003:0020 DEBUG: Code 100864261 at ueX$([U\RyQWMQ{AgE:29394758
001003:0020 DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29395011
001003:0020 DEBUG: Code 0 at 1I^He/VNrKbQou9i\-`:213129915
001003:0020 DEBUG: Code 0 at kstXQhz>sC3xud$ta/Bp:29394459
001003:0020 DEBUG: Code 13 at kstXQhz>sC3xud$ta/Bp:29393286
001003:0020 DEBUG: Code 0 at D8L"~H<8yPg*12}M1MpW{:213136608
001003:0020 DEBUG: Code 0 at \M2)&;{$qvan/C5Z1b9:213131870
AV sync issues in E:/incoming/temp/hb/Die Hard 4.0 (2007)_t00.mkv
AV sync in 1 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8ms
AV sync in 1 at 0:00:00 (8ms) : encountered overlapping frame, audio skew is +8ms
001003:0020 DEBUG: Code 0 at n\#}p`MV9XD.5{NB:29402279
001003:0020 DEBUG: Code 0 at *)sQF5!j965h>FtY#x;:121264556
001003:0020 DEBUG: Code 18 at kstXQhz>sC3xud$ta/Bp:29393286
001003:0020 DEBUG: Code 0 at =Vg37v50BDem9m'D){%:29396046
005003:0000 Failed to save title 0 to file E:/incoming/temp/hb/Die Hard 4.0 (2007)_t00.mkv
002023:0000 Encountered 11 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06031105 count=11 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 6 unclassified errors
error=0xC000009C count=6 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 0 titles saved, 1 failed
Application exited at Mon Jul 15 13:13:45 2019
Grauhaar
Looks like that the disc could not be read. Many Medium Errors and so on ....
Good Luck
Mr_Orange
Make MKV takes quite a long time to decide there is a disc and what is on it. It starts the rip and gets about 50% of the way through before quitting.Grauhaar wrote: Mon Jul 15, 2019 4:30 pm Looks like that the disc could not be read. Many Medium Errors and so on ....
I have cleaned the disc but to no avail. Is there anything else I can try or this particular disc just not going to rip?
I do have an LG BH16NS55 BD drive on its way so will try again with that in case it is a drive issue.
Mr_Orange
Same issues with the BD drive so it must be the disc itself.Mr_Orange wrote: Mon Jul 15, 2019 11:22 pmMake MKV takes quite a long time to decide there is a disc and what is on it. It starts the rip and gets a bit of 50% of the way through before quitting.Grauhaar wrote: Mon Jul 15, 2019 4:30 pm Looks like that the disc could not be read. Many Medium Errors and so on ....
