V14 Slowwwwwwwwww!
rjones049
V14 Slowwwwwwwwww!
#1 Post by rjones049 » Thu Nov 08, 2018 7:10 pm
Using MakeMKV without key, installed v14. Operations that previously took 15 minutes now consume 4-5 hrs.
Windows 10 Ent 1803
Intel I5 Quad
But also tried on three other machines, two on W7 SP1, with a similar result.
Did I miss some important announcement, or is this some new policy?
Re: V14 Slowwwwwwwwww!
#2 Post by mike admin » Thu Nov 08, 2018 8:26 pm
rjones049 wrote: Thu Nov 08, 2018 7:10 pm Using MakeMKV without key, installed v14. Operations that previously took 15 minutes now consume 4-5 hrs.
Windows 10 Ent 1803
Intel I5 Quad
Do you know why it is slow? What is the CPU/memory usage? Is it just the slow read speed or MakeMKV consumes some resources?
grinn253
#3 Post by grinn253 » Sat Nov 17, 2018 4:20 am
Its very slow for me as well. Disks that took ~ 20 minutes now take ~ 8 hours.
The slow part seems to be disk read (Blu-Ray), from disks back from 2010, to recent releases. Using Win7x64, no other programs/services running. Same machine/usage as was when running previous versions of MakeMKV. I will try to find a previous version and run that to confirm more.
Ed
grinn253
#4 Post by grinn253 » Sat Nov 17, 2018 4:24 am
I'm running MakeMKV version 14. Maybe version 14.1 is faster? I'll try that next! 8)
dragonfire
#5 Post by dragonfire » Sat Nov 17, 2018 7:33 pm
Are you trying to do audio conversions while ripping? I know when I installed 1.14.1, it started hammering my C drive disk with a temp file whenever I'd do a rip with AAC audio conversion on the fly. Even with an SSD as my OS drive, it would bring usage up to 100% and I'd have average response times in the 2000ms range. I have since rolled back to 1.12.3 to avoid this issue until it gets fixed.
grinn253
#6 Post by grinn253 » Sun Dec 02, 2018 6:43 am
Quick update to this. Indeed installing 1.14.1 remedied the slowness issue, so all is great now!
On that note, I just installed 1.14.2 a few moments ago...hopefully everything remains speedy!
MakeMKV: Thanks for great software support!
