I'm usually creating a backup of my 3D BRs. So far this worked without issues.
But starting with 1.12.3 I'm no longer able to backup a disk - when selecting "backup" makemkv takes about 5 seconds and then gives a message "backup failed".
Opening the disk and storing just parts of it however works - so makemkv seems to be able to read the disk.
I've now tried also the latest 1.14.1 - but same behavior (tested with Solo - A star wars story).
Reinstallig 1.12.2 - and "backup" works.
Did I miss a change in makemkv? Is there a new prerequisite to backup a disk now?
J
"Backup" no longer working?
Re: "Backup" no longer working?
Backup definitely works in 1.12.x and 1.14.x...
Do you have debug logging turned on? What does the log show for the attempt?
jeff98
yep. debug logging is on, this is what i get:
Of course "O:" is writeable and has enough free space (1.12.2 can backup the same disk to this drive without issues).
I'm also pretty sure that it is not related to the disk - as actually none can be backuped anymore.
Debug log started at Sat Nov 17 15:41:46 2018 , written by MakeMKV v1.14.1 win(x64-release)
Using 1048320KB for read cache.
001005:0000 MakeMKV v1.14.1 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Jeff/MakeMKV_log.txt
DEBUG: Code 2365587456 at q'(*`fMQ6kt8Paz::121274285
005072:0000 Backing up disc into folder "O:/backup/3DDisk"
001003:0020 DEBUG: Code 182 at ?Ntw=,+,HYRHLXmD9tN:213142220
001003:0020 DEBUG: Code 0 at ?Ntw=,+,HYRHLXmD9tN:29404671
001003:0020 DEBUG: Code 0 at J:DD4MJmHb7fW3P.]jTB:29396713
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Sat Nov 17 15:42:49 2018I'm also pretty sure that it is not related to the disk - as actually none can be backuped anymore.
This is a bug in 1.14.x - backup fails for some 3D discs. Opening the disc should work.
smartieyoung
I haven't really tried 3D discs so I wouldn't know.Regular backup Appears to me to work slow but still good given the fact I throw plenty of discs at it.Just out of of being curious does anyone seem to have a difference backing up 4K bluerays vs regularf blurays and DVDs? ive only done backups on a few UHD disks before so I would be curious to know
