I want to create a new Profile. I searched for the Default ones (Default, AAC-Stereo, Flac, WDTV) but I can´t find them on my whole PC.
I searched for all .XML files on my PC and for all with the ending mmcp.xml but there is None.
I thougt they has to be the here if I read correct here in the forum:
C:\Program Files (x86)\MakeMKV
and from there I want to copy it to here and change my parameters :
C:\Users\User\.MakeMKV
Please tell me where to find the "Default" one or post here the Content.
Where to find the default profiles on PC?
Re: Where to find the default profiles on PC?
The default profiles have been stored in the file appdata.tar, found in the MakeMKV program directory.
A program that understands .tar files is necessary to pull them out; I extracted them with the tar utility that comes with Linux and MacOS, but there are several programs (like 7zip) for Windows that can read them, too.
The profiles for 1.14.x have changed, but I haven't extracted them yet. You can see the earlier profiles in this thread:
https://makemkv.com/forum/viewtopic.php ... 14&p=64821
StripLV
OK i´ve extracted, but there is only one .bin file inside? No Profiles.... or .XML files
This is the contents that I found when I used `tar xfv appdata.tar`:
Note the 4 XML files, default.mmcp.xml, flac.mmcp.xml, wdtv.mmcp.xml, and aac-st.mmcp.xml.
Their contents are as follows:
sdf_0000002c.bin
makemkv_deu.mo.gz
makemkv_jpn.mo.gz
makemkv_spa.mo.gz
makemkv_ptb.mo.gz
makemkv_dut.mo.gz
makemkv_swe.mo.gz
makemkv_nor.mo.gz
makemkv_ita.mo.gz
makemkv_chi.mo.gz
makemkv_pol.mo.gz
makemkv_dan.mo.gz
makemkv_fra.mo.gz
makemkv_per.mo.gz
default.mmcp.xml
flac.mmcp.xml
wdtv.mmcp.xml
aac-st.mmcp.xml
sdf_00000042.bin
--index-C101C815ACA63500F1F465C8EE060B970F61D1B4.bin
<?xml version="1.0" encoding="utf-8"?>
<profile>
<!-- profile name -->
<name lang="eng">AAC-stereo</name>
<!-- Common MKV flags -->
<mkvSettings
ignoreForcedSubtitlesFlag="true"
useISO639Type2T="false"
setFirstAudioTrackAsDefault="true"
setFirstSubtitleTrackAsDefault="true"
setFirstForcedSubtitleTrackAsDefault="true"
insertFirstChapter00IfMissing="true"
<!-- Output formats -->
<outputSettings name="copy" outputFormat="directCopy">
<description lang="eng">Copy track as is</description>
<description lang="ger">Track 1:1 kopieren</description>
</outputSettings>
<outputSettings name="aac" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 AAC-LC</description>
<extraArgs>codec=libfdk_aac profile=LC</extraArgs>
<extraArgs>afterburner=1</extraArgs>
</outputSettings>
<outputSettings name="he-aac" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 HE-AAC</description>
<extraArgs>codec=libfdk_aac profile=HE-AAC signaling=explicit_sbr</extraArgs>
</outputSettings>
<!-- HE-AACv2 - stereo inputs only -->
<outputSettings name="he-aacv2" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 HE-AACv2</description>
<extraArgs>codec=libfdk_aac profile=HE-AACv2 signaling=explicit_hierarchical</extraArgs>
</outputSettings>
<outputSettings name="aac-gpl" outputFormat="AAC">
<description lang="eng">Save as Mpeg-4 AAC-LC (ffmpeg encoder)</description>
<extraArgs>codec=aac -strict -2</extraArgs>
<extraArgs>aac_coder=twoloop</extraArgs>
</outputSettings>
<!-- Audio downmix settings -->
<audioMixSettings name="stereo16"
outputBPS="16"
outputChannelLayout="stereo"
mix="DolbyPrologic2">
<description lang="eng">Stereo 16-bit Dolby PrologicII downmix</description>
</audioMixSettings>
<audioMixSettings name="stereo16raw"
outputBPS="16"
centerMixLevel="-3dB"
surroundMixLevel="-6dB"
lfeMixLevel="0">
<description lang="eng">Stereo 16-bit downmix</description>
</audioMixSettings>
<!-- Default rule - copy as is -->
<trackSettings input="default">
<output outputSettingsName="copy"
defaultSelection="$app_DefaultSelectionString">
</output>
</trackSettings>
<!-- For all audio tracks keep the original track
and produce additional AAC stereo downmix -->
<trackSettings input="LPCM-stereo">
defaultSelection="$app_DefaultSelectionString,-sel:all">
</output>
<output outputSettingsName="aac"
</output>
</trackSettings>
<trackSettings input="LPCM-multi">
</output>
audioMix="stereo16">
</output>
</trackSettings>
<trackSettings input="TRUEHD-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="TRUEHD-multi">
</output>
</output>
</trackSettings>
<trackSettings input="MLP-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="MLP-multi">
</output>
</output>
</trackSettings>
<trackSettings input="DTSHDMA-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="DTSHDMA-multi">
</output>
</output>
</trackSettings>
<!-- Save DTS-HD LBR (low quality) as AAC (just to decode),
do not keep original track -->
<trackSettings input="DTSHDLBR-stereo">
</output>
</trackSettings>
<trackSettings input="DTSHDLBR-multi">
</output>
</trackSettings>
<trackSettings input="DTS-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="DTS-multi">
</output>
</output>
</trackSettings>
<trackSettings input="AC3-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="AC3-multi">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-core-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-core-multi">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-stereo">
</output>
</output>
</trackSettings>
<trackSettings input="EAC3-multi">
</output>
</output>
</trackSettings>
<!-- Keep stereo AAC unchanged, add downmix for multichannel -->
<trackSettings input="AAC-stereo">
</output>
</trackSettings>
<trackSettings input="AAC-multi">
</output>
</output>
</trackSettings>
</profile>
<profile>
<!-- profile name - Default -->
<name lang="mogz">:5086</name>
<mkvSettings
<!-- This tag is ignored by MakeMKV 1.12.4 and later, do not change it here. Set the app_DefaultSelectionString
value in preferences. Keep this element in your custom profiles only for compatibility with older MakeMKV versions.
<profileSettings
app_DefaultSelectionString="-sel:all,+sel:(favlang|nolang|single),-sel:(havemulti|havecore),-sel:mvcvideo,=100:all,-10:favlang"
<!-- Output formats currently supported by MakeMKV -->
</outputSettings>
<outputSettings name="lpcm" outputFormat="LPCM-raw">
<description lang="eng">Save as raw LPCM</description>
<description lang="ger">Als RAW LPCM speichern</description>
</outputSettings>
<outputSettings name="wavex" outputFormat="LPCM-wavex">
<description lang="eng">Save as LPCM in WAV container</description>
<description lang="ger">Als LPCM im WAV-Container speichern</description>
</outputSettings>
<outputSettings name="flac-best" outputFormat="FLAC">
<description lang="eng">Save as FLAC (best compression)</description>
<description lang="ger">Als FLAC speichern (höchste Komprimierungsstufe)</description>
<extraArgs>-compression_level 12</extraArgs>
</outputSettings>
<outputSettings name="flac-fast" outputFormat="FLAC">
<description lang="eng">Save as FLAC (fast compression)</description>
<extraArgs>-compression_level 5</extraArgs>
</outputSettings>
</output>
</trackSettings>
<!-- Save LPCM mono or stereo as raw LPCM -->
<output outputSettingsName="lpcm"
</output>
</trackSettings>
<!-- Put multi-channel LPCM into WAVEX container-->
<output outputSettingsName="wavex"
</output>
</trackSettings>
<!-- Convert closed captions to text subtitles
This rule is added automatically by default if no
other <trackSettings input="CC"> tags are present.
Uncomment to override as needed. -->
<outputSettings name="convertToSRT" outputFormat="SRT">
<description lang="eng">Convert to text subtitles</description>
</outputSettings>
<output outputSettingsName="convertToSRT"
</output>
</trackSettings>
</profile>
<profile>
<name lang="eng">FLAC</name>
<mkvSettings
</outputSettings>
</outputSettings>
</outputSettings>
</outputSettings>
</outputSettings>
</output>
</trackSettings>
<!-- Save LPCM mono or stereo as FLAC -->
<output outputSettingsName="flac-fast"
</output>
</trackSettings>
<!-- Save multi-channel LPCM as FLAC -->
defaultSelection="$app_DefaultSelectionString,+sel:true">
</output>
</trackSettings>
<!-- Save TRUEHD as FLAC -->
</output>
</trackSettings>
</output>
</trackSettings>
</output>
</trackSettings>
</output>
</trackSettings>
<!-- Save DTS-HD as FLAC -->
</output>
</trackSettings>
</output>
</trackSettings>
<!-- Save DTS-HD LBR (low quality) as FLAC (just to decode) -->
</output>
</trackSettings>
</output>
</trackSettings>
</profile>
<profile>
<name lang="eng">WDTV</name>
<mkvSettings
</outputSettings>
<outputSettings name="copyzlib" outputFormat="directCopy">
<description lang="eng">Copy track as is (zlib compressed)</description>
<mkvTrackSettings compression="zlib" compressionLevel="9" />
</outputSettings>
</outputSettings>
</outputSettings>
</outputSettings>
</outputSettings>
</output>
</trackSettings>
</output>
</trackSettings>
</output>
</trackSettings>
<!-- Compress PGS subtitles with ZLIB compression -->
<trackSettings input="PGS">
<output outputSettingsName="copyzlib"
</output>
</trackSettings>
<trackSettings input="PGS-forced">
</output>
</trackSettings>
</profile>
