Juliet, Naked Playlist please
Crtguy
Post by Crtguy » Wed Nov 14, 2018 8:53 pm
Please help. Can't get playlist with Java. Netflix
johng
Re: Juliet, Naked Playlist please
Post by johng » Thu Nov 15, 2018 4:12 am
When I read the disc with MakeMKV it picked this as the main feature playlist. I have no idea if it's correct, so if anyone can verify please post.
Title information
Name: Juliet, Naked (English)
Comment: FPL_MainFeature
Source file name: 00753.mpls
Duration: 1:37:34
Chapters count: 16
Segment count: 20
Segment map: 519,505,506,513,518,512,517,520,511,504,510,501,516,503,509,502,514,515,507,508
File name: Juliet,_Naked_t01.mkv
flintstone198
Post by flintstone198 » Thu Nov 15, 2018 4:37 am
netflix
Source file name: 00647.mpls
Duration: 1:37:34
Chapters count: 16
Segment count: 20
Segment map: 519,512,505,517,506,513,518,520,511,504,510,501,503,516,509,502,507,515,514,508
enjoy
Crtguy
Post by Crtguy » Thu Nov 15, 2018 1:22 pm
johng
Post by johng » Thu Nov 15, 2018 3:06 pm
What gets updated so MakeMKV will pick the correct playlist?
Lovely Rita
Post by Lovely Rita » Thu Nov 15, 2018 3:53 pm
johng wrote: Thu Nov 15, 2018 3:06 pm What gets updated so MakeMKV will pick the correct playlist?
How do you know that yours is NOT correct?
Was your Netflix, also? You did not note retail, Netflix, Redbox, etc. :wink:
Registered User :wink:
Buy MakeMKV
hvnphoto
Post by hvnphoto » Thu Nov 15, 2018 4:52 pm
Retail Version is also 00647.MPLS.
johng
Post by johng » Thu Nov 15, 2018 5:54 pm
I'm assuming mine isn't correct because there have been other posts when makemkv doesn't select the correct movie - that's why I asked my question about how makemkv ultimately gets updated to select the correct playlist or maybe it never does??? By the way mine was also a netflix rental. I'm not sure how the other poster figured out that 00647 playlist is correct? I'm guessing they used the process monitor technique that has been discussed in many threads? That technique always talks about using PowerDVD to actually play the bluray, but I'm wondering if anyone has gotten it to work using VLC (since I don't have PowerDVD)? The link below says you can get VLC to play blurays - anyone tried it?
https://www.quora.com/How-can-I-play-Bl ... Windows-10
johng
Post by johng » Fri Nov 16, 2018 5:33 am
OK, I can confirm my previous post (with link) regarding getting VLC to play bluray's works on Windows 10. Make sure you put the .cfg file in "C:/users/yourname/AppData/Roaming/aacs/" folder, and make sure you put the 64bit .dll in "C:/Program Files/VideoLAN/VLC/" folder (or the 32bit version in "C:/Program Files (x86)/VideoLAN/VLC/" folder).
Once you do that you should be able to open VLC, click on "Media/Open Disc...", select Bluray, select your Bluray drive, and then hit play. You'll get this error but it doesn't matter - "This Blu-ray disc requires Java for menus support.Java was not found on your system. The disc will be played without menus."
Next up I'm going to install process monitor and see if I can get the correct playlist like all these youtube links show you how to do, but using VLC instead of PowerDVD. I'll post details once I get it working.
https://www.youtube.com/watch?v=AlhBmIbReao
https://www.youtube.com/watch?v=Zuz1sM4LRTw
https://www.youtube.com/watch?v=dFS9BFhxR9k
johng
Post by johng » Fri Nov 16, 2018 7:42 pm
OK, downloaded process monitor and followed the steps from the first youtube video and got the correct playlist (but the the disc wasn't an obfuscated one). Then checked another bluray and VLC wouldn't even play it, so it turns out this is a bit more complicated than my original post. After a bit of looking I found a huge thread over at VideoLAN forum (see link below) on Bluray support for VLC. Once I figure out all the steps I'll post in a thread of it's own so it's not buried here.
https://forum.videolan.org/viewforum.php?f=14
Steveredrum
Post by Steveredrum » Thu Nov 22, 2018 1:51 am
00647.MPLS Got My Untouched Standalone Blu-ray Disk Working 100% - Thanks
andcbii
Post by andcbii » Fri Oct 16, 2020 8:51 pm
flintstone198 wrote: Thu Nov 15, 2018 4:37 am netflix
Duration: 1:37:34
Chapters count: 16
Segment count: 20
enjoy
Thank you, this was the correct list for me as well.
