Goodbye Christopher Robin
IronRod
Post by IronRod » Thu Nov 15, 2018 2:36 am
Originally tried with 1.14.0 then tried with the 1.14.1. Same results from both.
While getting the catalog from "Goodbye Christopher Robin", it gets about 80% done and then fails. I hear the head moving some -- about 5-10 times -- and then it starts giving Scsi Errors:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..00C04 to device 'SPTI:\Device\CdRom0'
See full log output at bottom.
Using VLC, I was able to play the movie (fast speed) directly from the disc all the way to the end. So, I don't think it is a defect in the disc.
Title #1 was added (25 cell(s), 1:46:41)
Title #2 was added (1 cell(s), 0:02:35)
Title #3 was added (1 cell(s), 0:02:11)
Title #4 was added (1 cell(s), 0:02:02)
Title #5 was added (1 cell(s), 0:02:32)
Title #6 was added (1 cell(s), 0:02:18)
Title #7 was added (1 cell(s), 0:02:25)
Title #8 was added (1 cell(s), 0:03:19)
Title #9 was added (1 cell(s), 0:02:33)
Title #11 was added (1 cell(s), 0:02:32)
Title #12 was added (1 cell(s), 0:02:29)
Title #13 was added (1 cell(s), 0:03:08)
Title #13/1 was added (1 cell(s), 0:02:37)
Title #14 was added (1 cell(s), 0:02:29)
Title #15 was added (1 cell(s), 0:03:08)
Title #16 was added (1 cell(s), 0:02:37)
Title #17 was added (1 cell(s), 0:02:29)
Title #18 was added (1 cell(s), 0:03:08)
Title #18/1 was added (1 cell(s), 0:02:37)
Title #19 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20/1 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 3 in VTS 5 is equal to title 2 and was skipped
Title 1 in VTS 5 is equal to title 2 and was skipped
Title 3 in VTS 6 is equal to title 2 and was skipped
Title 1 in VTS 6 is equal to title 2 and was skipped
Title 4 in VTS 6 is equal to title 2 and was skipped
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0040..00C04 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0060..00C04 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0080..00C04 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..00B0..00C04 to device 'SPTI:\Device\CdRom0'
Error 'Internal error - Operation was cancelled (65)' occurred while issuing SCSI command A30..00C03000A0..05CE37341210..0 to device 'SPTI:\Device\CdRom0'
Grauhaar
Re: Goodbye Christopher Robin
Post by Grauhaar » Thu Nov 15, 2018 5:39 am
Please provide the full debug log.
To enable it; go to: "Preferences -> General -> Log Debug Messages" and restart MakeMKV
Good Luck :)
